Old 01-28-2016, 09:00 AM   #1
Galdo76
Galdo76's Avatar
Door Locks Jamming
Here's my issue. I have a 67 C10. I purchased a new door lock set, latches, and striker plates from LMC. The door closes fine, I can lock and unlock it from the inside and outside just fine. The problem is, if either door is locked and I push in the door handle button from the outside, the door pops open partially and the latch jams up. I found out by accident when I was putting the door back together and had to use quite a bit of force on the latch rod to unlock it.
It would be a nice security feature but unfortunately, if a crook tried to pop the door and can't get in, well then, neither will I.
I was under the impression that if the door was locked and someone pushed in the door handle button to try to open the door, it would just press in freely and nothing would happen until the door was unlocked. Am I missing something other than my sanity?
Galdo76 is offline   Reply With Quote
Old 01-28-2016, 10:41 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Door Locks Jamming
I'm guessing that the replacement door latches may be made a little different than the originals. I have had original latches do that if they were worn, but if you push in hard on the door it would re-latch and then you could unlock and open the door normally....
LockDoc
Leon
Old 01-28-2016, 11:08 AM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
If the door is locked and you push in the outside handle button, it should not push in.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
