Old 01-29-2016, 10:48 PM   #1
lyrikz
PITbut
lyrikz's Avatar
simple question? fender to hood gap.
I just installed 1968 front fenders, hood, and core support and everything fits ok the only issue that I am having is that the rear part of the fenders towards the door are super tight against the hood but the gap up near the core support is fine do I just shim the rear of the fenders to get the gap I need. It's tight on both sides.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 01-29-2016, 11:41 PM   #2
davepl
davepl's Avatar
Re: simple question? fender to hood gap.
I'm not a bodyman, but I'd think so. Normally you start with what you can't change (the cab) and build out from there. Particularly if the gap is OK up front, I think expanding it back at the base of the hood makes sense.
Mine had 1-2 shims from the factory, so just so you know, the factory -did- shim them. Not like gaps on GM trucks from the 60s are tight!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-30-2016, 12:12 AM   #3
swamp rat
swamp rat's Avatar
Of the two upper bolts by the cowl, my fenders had a single shim in both of the forward bolts and none on the back bolts, i didn't measure them but they are about .050 thick.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-30-2016, 11:34 PM   #4
lyrikz
PITbut
lyrikz's Avatar
I'm shimmed about half an inch if not 3/4 of an inch.
I think the hood has flattened out. I need to put a bit of a bend back in the hood. I just found out today that I have the wrong core support bushings but that isn't going to affect the hood width.
and sold.
