Old 02-06-2016, 12:05 AM   #1
SnapOnBodytech87
Power steering box mounting bolts
Where does the longer 7/16 bolt and this spacer go (in which hole) of the power steering box? Can't find it it my pictures thanks!
SnapOnBodytech87 is offline   Reply With Quote
Old 02-06-2016, 11:16 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Power steering box mounting bolts
Neither of my 1972 and 1969 trucks have a spacer. I've removed at least a half dozen steering boxes off of 1967 to 1972 trucks... never seen a spacer. Sorry... no clue.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-06-2016, 12:43 PM   #3
SnapOnBodytech87
Yea I'm thinking it's not used in this case because Ithe power steering box sits flat up against the frame. I know it came off with this steering box but I could have been on the inside of the frame rail to acomodate the longer bolt, one bolt is 2 " the other are 1 1/4".should I just put it on the inside?
Old 02-06-2016, 01:41 PM   #4
GASoline71
GASoline71's Avatar
I'd just get a shorter bolt and ditch the spacer.
Gary
Old 02-06-2016, 08:20 PM   #5
dozerbill72
dozerbill72's Avatar
I don't know the reasoning for it but the spacer goes on the inside of the frame. Mine is in the front bottom hole and I don't think it has ever been apart.
dozerbill72 is offline   Reply With Quote
Old 02-07-2016, 01:06 PM   #6
SnapOnBodytech87
Front bottom hole facing the front of the truck, looking from inside the frame rail?
Old 02-07-2016, 02:24 PM   #7
dozerbill72
correct
