Old 02-06-2016, 06:44 PM   #1
DakotaKid
67-72 fleetside rear bumper on our trucks.
Ive seen a few pictures of this and was hoping someone could post more pictures and possible the install and what they had to do to make brackets for it. I am really liking the way these look.
Thanks in advance guys!
Aaron
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 02-06-2016, 08:10 PM   #2
MisterC
MisterC's Avatar
Re: 67-72 fleetside rear bumper on our trucks.
Just use the 67-72 fleetside brackets that go with the bumper and it will bolt right up.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 02-06-2016, 08:24 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I just did this and what MisterC said is spot on.
See my post earlier today
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-06-2016, 08:25 PM   #4
jayoldschool
Moderator
Fits perfect, and looks like it was made for our trucks. Great mod.
jayoldschool is offline   Reply With Quote
Old 02-07-2016, 01:17 AM   #5
DakotaKid
Kinda hard when im using a 62 frame. I guess I should have stated that.
Old 02-07-2016, 11:25 AM   #6
Clyde65
Clyde65's Avatar
60-62 frames are 8" wider than 63-72, im not sure how you can do that other than some serious fab. Good luck!
Clyde65
Rebuild of Clyde
support our troops!
Old 02-07-2016, 11:48 AM   #7
LVPhotos
LVPhotos's Avatar
I had the 60-62 brackets for a stock bumper. After several bad looking chrome bumpers I swapped over to the 67-72. I cut the bracket to fit. Some flat stock would work just the same. If a welder is not available find something prebent that can cut.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
