Need Gear Vendors OD Dimensions
I know there were a couple of the Squarebody group that had GV OD units in their trucks. I looked on their website but don't see the dimensions to get an idea if one of these units will fit under my truck w/o a domino effect. They list the tailhousing assembly circled in yellow @ 12.25" (TH400/mech speedo app) but don't list the dimensions of the other section circled in red.
This could possible interfere w/my exhaust crossover and/or exhaust flanges. Does any have the length for the adapter portion in red?
Re: Need Gear Vendors OD Dimensions
Wish I still had that dually Id gladly measure it for ya. Sold it and bought a 91 crew with the 4l80.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
At the body shop.
18-3/8
" That didnt make it any newer " " Dont antique the equipment " |
At the body shop.
A friend has a new one and about to install it, that was from the adapter to the rear seal.
I know the pieces fit
So that's those two pieces combined, and it replaces the 4" tailshaft?
Would it be possible to snag a pic of the assembled unit if you're able?
#8 | |
On the ones I've installed, shortening the driveshaft is a must, and sometimes changing the exhaust around if you have an X pipe. Sometimes floor mods are needed in some cars as the tunnel gets a little tight back there on some models. |
#9 | |
At the body shop.
This weekend, his wife didn't appreciate the new parts in the kitchen...
My 83 C20 has a GV unit but I have a SM465 granny so the adapter is different. Driveshaft must be shortened and rebalanced - that balancing is critical or you will get a bad vibration.
I knew the driveshaft had to be cut & re-balanced. It was the closer inspection of the length that surprised me. Might re-think the 4l80e....
Here are some photos of the GV unit on my Suburban.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#13 |
So is the GV unit eorth it or should an owner switch to a 4l80?
#14 |
And there is also the option of using a 4L80E and GV so you get double overdrive. With the double overdrive setup on my vehicle, the RPM's at 60 mph is 1250 RPM's. The engine is barely off an idle at that speed.
#15 |
Cant decide what way to go wit my 89.
#16 | |
At the body shop.
More pics....
#17 |
Visually, that has more bulk to it vs what I saw from the dimensions pic on their website. What is your buddy's specific app? Mine is a th400/mechanical speedo so I wonder if that's part of it?
#18 |
The unit is not bulky. However, the length combined with the NV5600 transmission and NP205 transfer case creates quite a short drive line.
#19 | |
At the body shop.
Tbi 7.4 TH400 ext cab dually
#20 |
At the body shop.
Used to be a guy in town, 55 chevy 502 bbc TH400 and GV overdrive ran mid 11's did 1-2-2 over-3 over at the track.
Seemed tough enough and fit.
#21 |
Will he be shifting the trans x-member back? it's difficult to visualize if the mount is affected. I recall it being part of the case vs the tail housing but need to crawl under mine to confirm.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-09-2016 at 10:54 AM. |
#22 |
Definitely tough enough, they are rated to about 2,000 hp. It's what most of the drag week guys with auto's use that race down into the 7 second zone at over 200 mph and then drive the car between tracks.
#23 | |
But, I didn't notice this mass in the website pics.....
#24 |
At the body shop.
I believe they have 2 different pans as well.
#25 |
If you read the GV website you will find that they say adding a GV to an overdrive transmission will not increase fuel economy, just create a better towing experience.
| Bookmarks |
