Old 02-09-2016, 05:01 PM   #1
jmillsUT28
Help me figure out what Steering Stabilizers I need
What started as "I want to clean up my engine bay" turned into a taking the dang engine out and painted everything...
While I am deep in it I figured I should replace the shocks and the steering stabilizer. Here's a picture of what's on my 72 Blazer.
[IMG][/IMG]
Should it have both of these? I was thinking it should only have one the black one. If so can I take the yellow one off and just buy a new black one? Or should I replace both?
jmillsUT28 is offline   Reply With Quote
Old 02-09-2016, 05:03 PM   #2
geunther
geunther's Avatar
Re: Help me figure out what Steering Stabilizers I need
You should only need one. Sometimes people put two on because of having large tires. What size are you running?
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 02-09-2016, 05:06 PM   #3
jmillsUT28
Right now there are 31 on there but I am putting 33" with stock height. This will not be trailed just for street.
Old 02-09-2016, 08:08 PM   #4
swamp rat
swamp rat's Avatar
I run a single with 33" tires, no problem.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-09-2016, 10:21 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
x2 - ditch the yellow one. The tie rod bracket for the black one looks to be OEM, keep that. Rockauto recently had usa made examples for a good price.
Old 02-10-2016, 09:30 AM   #6
jmillsUT28
Awesome that's what I was hoping for. Thanks guys.
Old 02-10-2016, 10:24 AM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Sometimes people will install two because of other problems. Check your ball joints, tie rod ends and drag link ends for wear. One stabilizer should be sufficient for 33" tires.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-10-2016, 02:03 PM   #8
jmillsUT28
Will check everything out while I am in there. Thanks
Old 02-10-2016, 02:05 PM   #9
davepl
davepl's Avatar
Since the thread is handy - I ordered one for my 2WD Longhorn. Does it make any sense to run them on a 2WD? Since my 1975 Monte Carlo was clearly 2WD and it had one from the factory, I figure they must provide some benefit.
I do have a little bit of "hunting" on center on the highway, even freshly aligned. But no death wobble from railroad tracks yet... but I think that might only be a 4WD thing, no?
Basically, I have one but haven't installed it because I don't know if it'll provide a benefit.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-10-2016, 03:14 PM   #10
Ol Blue K20
I'm not sure of a noticeable benefit but it won't hurt it either.
Dale
