Old 02-10-2016, 04:08 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Is this Dash Cut ?
With this 80's cassette player installed do you think the dash has been cut?
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 02-10-2016, 04:10 PM   #2
MikeB69C10
MikeB69C10's Avatar
Re: Is this Dash Cut ?
Not necessarily cut. I had a 80s alpine cassette player with a similar look and my dash was not cut.
MikeB69C10 is offline   Reply With Quote
Old 02-10-2016, 04:11 PM   #3
Tuff Gong
Tuff Gong's Avatar
I think there is a good chance it is still original.
Tuff Gong is offline   Reply With Quote
Old 02-10-2016, 04:17 PM   #4
Already Gone
Thanks for the reply. I can see the cassette player is not as wide as the CD players. I'd never cut a dash but if it was already cut then I could install a modern car audio.
Old 02-10-2016, 04:25 PM   #5
sloth454
sloth454's Avatar
Yeah doesn't look like its cut. Looks to be about the same style as what is in my truck. My truck has an old cassette deck in it. I took it out and gutted all the components out of it. Makes a perfect Ipod holder. I made a custom mount in the glove box and put a new cd deck in there.
sloth454 is offline   Reply With Quote
Old 02-10-2016, 04:42 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Doubtful it has been cut, I've seen a lot of those double shaft 80's stereos in our trucks, and they are usually a direct fit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-10-2016, 06:24 PM   #7
im4darush
Mine had one of those. Direct fit, not cut.
im4darush is offline   Reply With Quote
Old 02-10-2016, 07:42 PM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Alot of those type stereos have adjustable shafts eliminating the need to cut/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-10-2016, 07:52 PM   #9
frenchy51
frenchy51's Avatar
Anybody know if a "modern" CD player will fit original dash without cutting?
frenchy51 is offline   Reply With Quote
Old 02-10-2016, 09:19 PM   #10
swamp rat
swamp rat's Avatar
No
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-11-2016, 12:00 AM   #11
El Dorado Jim
I currently have one in my '72 that looks like yours , dash is not cut
El Dorado Jim is offline   Reply With Quote
Old 02-11-2016, 12:24 PM   #12
I've been putting in-dash AM/FM/Cassettes in these trucks since the '70s with no issues. I have a sweet Alpine stereo & amp waiting to go in my '72. I've seen people toss these out to put an AM in and never understood that, unless it was to have an all original truck. I have had some stereos that needed the two holes filed out some for wider or narrower shafts
Old 02-11-2016, 12:53 PM   #13
swamp rat
swamp rat's Avatar
There is a place that can convert a stock unit to add a 3.5mm plug to play your Ipod or phone music and blue tooth.
http://67-72chevytrucks.com/vboard/s...dio+conversion
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-11-2016, 02:05 PM   #14
57larry
take the radio out and look at the dash. it does look like a good fit
57larry is offline   Reply With Quote
Old 02-11-2016, 02:13 PM   #15
Already Gone
That would be hard at this point as the truck is 1800 miles away and I'm thinking of buying it and as you said it looks like a good fit. I asked the seller if the dash was cut and he doesn't know as he bought the truck with the cassette player installed.
Old 02-11-2016, 07:59 PM   #16
All the seller has to do is pull the knobs off, then the plate, and expose the area to get you a picture
Old 02-11-2016, 10:35 PM   #17
swamp rat
swamp rat's Avatar
I can tell you from past experience tho that if it was cut the radio knobs would have nothing to hold on to except that plastic face plate, if it did that it would most likely not sit in the opening very well and the face place would be stress bent inward, it looks nice and flat..
I have ran 4 different cassette players like that thru the years and never had to modify the opening in any way.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-11-2016, 11:24 PM   #18
custom10nut
custom10nut's Avatar
Keep it intact, modify the knob to put stock l
Knobheads, and install an IPod hookup for your iTunes. (That's what I did) Or install a hookup for a remote CD changer. Lots of options without cutting a good dash
custom10nut is offline   Reply With Quote
Old 02-12-2016, 12:17 AM   #19
Already Gone
Thanks for all the tips, ideas and replies. As I said if its cut I'll install a modern player in it and if its not cut probably a stock AM radio with a http://www.garytayman.com/stereo.htm conversion.
