Old 02-19-2016, 12:32 AM   #1
JacobSchni
JacobSchni's Avatar
dodge d60 axle swap?
Buddy of mine has a d60 from a dodge for a cheap price. anyone ever swap or have any info on swapping to k10
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz
680hp/720ftlbs of NA fun
JacobSchni is offline   Reply With Quote
Old 02-19-2016, 05:58 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: dodge d60 axle swap?
Front or Rear?
Rich
1972 K5 Blazer CST Click HERE
Old 02-19-2016, 06:24 AM   #3
andrewmp6
If its from a leaf spring truck you can use the front axle.You will need these http://offroaddesign.com/catalog/Dod...apBushings.htm and i believe the lugs are a different size them a gm truck uses.
andrewmp6 is offline   Reply With Quote
Old 02-19-2016, 04:42 PM   #4
JacobSchni
JacobSchni's Avatar
front.
Old 02-19-2016, 04:49 PM   #5
JacobSchni
JacobSchni's Avatar
heres some pics
Old 02-19-2016, 04:54 PM   #6
JacobSchni
JacobSchni's Avatar
and heres a 14ff i might be getting. looks good for $250. and it already has 4.10 gears.
Old 02-19-2016, 05:05 PM   #7
JacobSchni
JacobSchni's Avatar
250 a good price for a 14ff?
Old 02-19-2016, 05:06 PM   #8
74CustomK20
74CustomK20's Avatar
Looks like that axles got new fluid in it. I hope he sealed it back up though...
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 02-19-2016, 06:33 PM   #9
JacobSchni
JacobSchni's Avatar
im going to check it out tomorrow
Old 02-19-2016, 06:34 PM   #10
JacobSchni
JacobSchni's Avatar
dont know about that d 60 guy want 500 for it and it look kinda rough. it has 355 gears welded and need new brake parts as you can see
Old 02-19-2016, 07:03 PM   #11
slotard
To me and around here 250 seems steep for a 14ff with open diff but I'm sure location matters. I'd love to get that for mine once I swap the locked 373 in.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-20-2016, 12:22 AM   #12
cadillac_al
That D60 probably has the spring perches spaced different than a Chevy, not sure though. I see 3/4 ton axles for sale pretty cheap from time to time but $250 isn't bad.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-20-2016, 12:28 AM   #13
USSkoval
It's only a 1/2 inch different. Easy to overcome if using lift springs, you can get 1/4 inch offset bushings just for that purpose. The Dodge axle has many minor differences, but it's still basically a direct swap into a GM truck.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 02-20-2016, 01:10 AM   #14
JacobSchni
JacobSchni's Avatar
if the spring perches are different, which i assumed were. ill just relocate and weld new ones in
Old 02-20-2016, 03:29 AM   #15
andrewmp6
The off road design spring bushings i linked you to fix the spring width problem.
Old 02-20-2016, 11:01 AM   #16
74CustomK20
So it's a half inch farther out or in? I seen a few come up recently, and honestly that's awesome!
Big Nate
Old 02-20-2016, 12:31 PM   #17
enaberif
Geezus $250 for a 14bolt FF?! That is a steal for where I am from.
enaberif is offline   Reply With Quote
Old 02-20-2016, 01:29 PM   #18
slotard
I guess it all depends on where you are. I see stock 14FFs for less than that all the time.
As with old trucks, I imagine I could make a fair amount of money by buying them here and shipping them to rusty areas. I wouldn't feel as bad doing it with parts as clean trucks, though.
1973 C20, 350/350
Old 02-20-2016, 06:51 PM   #19
USSkoval
A lot of folks have just pulled the springs together with a ratchet strap and bolted the thing right in. It seems like hack, but it does work fine.
But like was mentioned before, if using narrower aftermarket springs, just use offset bushings or space with washers.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 02-20-2016, 09:18 PM   #20
russgt
russgt's Avatar
I think you are OK price wise, especially since the 60 has single wheel hubs.
I saw your hood ad of FB, I'll have to ask you about the big block parts sometime.
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 02-20-2016, 10:03 PM   #21
74CustomK20
USSKOVAL I thought of that, but since I have 52" Springs up front I have spacers on either side, so I think that'll work out good...
Big Nate
Old 02-20-2016, 10:31 PM   #22
Auctioneerhere
The Dodge D60 will work. I've done it and it is simple.
Be prepared to change out the shock mounts.
You have to be a tad creative with the brake lines.
I recall grinding a tad on the side of leaf springs to get the u-bolts by easier.
After doing it once, in the future I would just get the right Chevy axle to begin with.
Auctioneerhere is offline   Reply With Quote
Old 02-20-2016, 11:25 PM   #23
USSkoval
Yeah, you are set with 52's, you have room for adjustment.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
