02-20-2016, 07:00 PM | #1 |
custom engine bay wiring ideas for LS swap
I have smoothed out most of my firewall, got rid of the heater box and all holes other than the necessary ones. I am putting a 5.3L in it and am wondering where have you guys ran the harness so it's very clean and not visible. I am going to be putting the fuse panel and ecm under the dash in behind the glove box. Anything helps so keep it going. I was going to do a bulkhead connector for the engine and body harness so it's sealed and easy to access.
02-20-2016, 08:12 PM | #2 |
Re: custom engine bay wiring ideas for LS swap
Check out the LS swap section for ideas and also may be a better place to ask this question.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-20-2016, 10:59 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Some aftermarket harnesses run under the intake....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
