Starter on a 305 with 1 terminal
Just dropped a later model 305 in the 72. Question is I had 2 wires going to 2 terminals on the 350... ,how do I connect them now we ith only one terminal on 305 starter? Can I just use my old solenoid or what? Thanks
Re: Starter on a 305 with 1 terminal
Are you still using points ignition? That's what the yellow wire (relay) is used for.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
No its got hei
So I can connect the other wire to the one terminal snd its good?
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's the wiring. The pink wire is where the purple goes and nothing goes to the outside terminal with HEI ignition. BTW how did you wire the ignition to the HEI BAT distributor terminal?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Po wired it to fuse block. ThAnks for help
