Old 02-28-2016, 09:12 PM   #1
70 c10 rook
70 c10 rook's Avatar
Rear axle codes and help
So I'm converting my 70 from 6 to 5, and I have this code on the rear axle TDE 0522K that is on the pass. Axle tube on the pass. Side yolk I have 3896838 and on the driver side yolk there is GM10. I have done some reader has and found out that most likely has 3.07 gears. Are these any good will they get up some speed I'm going to keep my 350 4 barrel pretty much stock. Can anyone give me some input on this I will eventually have 18x8 and 18x 10 tires and wheels. Thanks for your help
70 c10 rook is offline   Reply With Quote
Old 02-28-2016, 09:55 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rear axle codes and help
3.07 would be correct. All you need is the "TDE". Here is a link to the ratio charts I posted a few years ago. The 3.07 is a pretty high gear but it should work pretty good with your current setup, presuming you have a TH350.... Not sure when you go with the 18" wheels though, you may not have any low end left at that time.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 02-28-2016, 10:43 PM   #3
70 c10 rook
Does the 0522K or the other two numbers mean anything,and yes it does have a th350
Old 02-28-2016, 10:49 PM   #4
LockDoc
LockDoc's Avatar
I think the 0522k may be a date code & the 3896838 should be a part number. I don't know what the GM10 is for.
LockDoc
Leon
