What the heck is this part?
I'm cleaning things up on my new-to-me 79 C10. It was an A/C truck at some point, but over half the system is gone so I'm trying to tidy up what is left. This part has what I assume is a vacuum line going to it, and I can see the line is teed off in the dash.
What is it? Do I need it for something else? ![]() |
Re: What the heck is this part?
that is a vacuum reserve cannister. It helps buffer the vacuum load on the engine when all the A/C doors ore moving. Do you need it.. if you removed the A/C and went to cable operated heater and vents, no. If your outlets are still vacuum operated, it will help but is not strictly required.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Cruzzzn' Vet
Have 2 of those on my 83 but mine are round, back when I was in the NAVY when working on the truck some guys would ask me what those were, I would tell them those are my emergency brake blow down bottles
Sounds good, thanks. So what should I do with the line going to it? Cap it at the tee, or will that cause an issue?
If it's nkt obvious, I'm not very familiar with vacuum systems. |
My 83 has two vacuum reservoirs - one on the left firewall near the wiper motor and one on the extreme right side near the a/c box. One is for the a/c system and one is for the cruise control system (if I recall correctly.) Personally, I would try to restore your a/c system if you can - it is a very nice feature to have. Cruise control is nice also, but I would go with an aftermarket electronic cruise since the vacuum operated ones are problematic for me.
My truck doesn't have cruise, and the A/C system is so far gone it woud be a major deal to get it back. This truck is far from a daily driver, and I'ma windows down fresh air kinda guy. Plus, I'm in Wisconsin not the desert, so I should be allright.
Just roll the windows down and "smell the dairy air."
Just cap it, or hook it up and cap the outlet or remove hose and cap at the engine.
1979 K10 Silverado SWB 1981 K30 Scottsdale Crew Cab SRW 1988 v30 Silverado single cab DRW 1991 K20 Suburban barn door |
