Old 03-01-2016, 03:08 PM   #1
jr1966
front suspension question
I am still working on this 69 GMC and have a problem, I think. I put the floor jack under the middle of the front crossmember and jack. As it comes up enough to try and clear the tires the right wheel stays pointed straight and the left starts toeing in like in a right turn and stays that way while up. The front is a later model with power steering and disc brakes and all new other pieces, A arms ,tie rods , idler arm.
Now is this normal or do I have something wrong ? I am new to this truck stuff.
Thanks, JR
jr1966 is offline   Reply With Quote
Old 03-01-2016, 09:26 PM   #2
PGSigns
PGSigns's Avatar
Re: front suspension question
As the wheels drop the tie rods also drop and will cause toe in. Most the time its no to extreme.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-15-2016, 02:03 PM   #3
jr1966
Also when sitting still and turn the wheel the front end dips up and down with wheel movement right and left. Kinda weird to be sitting and it move up and down. I can't see anything wrong with the suspension,
Any ideas?
Thanks JR
Old 03-15-2016, 08:08 PM   #4
PGSigns
PGSigns's Avatar
Post pictures that sounds like something is bent.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-17-2016, 08:59 AM   #5
chase@ridetech
chase@ridetech's Avatar
Any ideas?
Thanks JR
What is your caster set at? The king pin inclination will cause the movement up and down as it goes side to side. The more caster typically the more movement.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 03-17-2016, 09:06 AM   #6
chase@ridetech
Thanks, JR
Measure your tie rods center to center for both sides. Also, with the steering wheel centered, count the number of turns that you make make to the left and then front center count the number of turns you can make to the right. If the steering wheel was ever put on "off center" and then centered by adjusting the tie rod ends it could create this issue.
Chase Mundy
Old 03-17-2016, 09:10 AM   #7
robnolimit
robnolimit's Avatar
check the condition of the Idler Arm.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 03-17-2016, 12:08 PM   #8
jr1966
I am going to try to get a few pics. All parts are new and later model than 69. haven't even got it dirty yet. Seems to drive OK. I have to figure out how to post pics next.
Thanks JR
