Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-02-2016, 10:13 PM   #1
GMCshorty
rear springs with caltracs
Hey everyone. For those of you running Caltracs, are you running the split monos or a multipack? If so, what spring rate for the multipack? I have a 71GMC short box with big block and a 4 speed and hoping I can get it to hook. Its a street truck but might see the track a bit. It has a 12 bolt with 3.42s. Thanks, Troy.
GMCshorty is offline   Reply With Quote
Old 03-05-2016, 10:51 PM   #2
pistonbroke800
pistonbroke800's Avatar
Re: rear springs with caltracs
I'm dong a bunch of work to my suspension right now and Caltracs are part of the project. I am going to be using the stock springs that are 3 leafs and the over load. I'm hoping with good shocks and 325/50R15 M/T's it will hook my 496 TH400 3:73's.
pistonbroke800 is offline   Reply With Quote
Old 03-06-2016, 09:31 AM   #3
HAULIN' IT
This is what I have except I have removed the overload.
I have been using stock type springs for about 8 years...I'm needed to replace my 3rd pair. The first (originals) broke...I blamed it on being old & scared to death, the replacements bent & so has the set that is on there now. I have purchased the parts to make an anti-roll bar which seems to be the problem. The main Right spring seems to flatten out & the Left one kinks toward the front. At some point I may go to the split mono's.
My advice, If you are going to use multi leafs & are going to the track with sticky tires...do the anti-roll bar now. Lorne
It goes 1.56-8 60' times. You can see some rollin' over going on.
Here's from the other side of the track...you can see the whole rear tire in the wheelwell
HAULIN' IT is offline   Reply With Quote
Old 03-07-2016, 09:15 AM   #4
djracer
djracer's Avatar
We ran split monos on my friends 67 Camaro and had 1.42 60ft on a 200 shot progressive with a 275 60 15 drag radial
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-07-2016, 12:14 PM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
The split monos fix the bending problem . The front half is very thick and the rear section is actually the spring rate portion .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
