Old 03-05-2016, 11:20 PM   #1
crazyjim
crazyjim's Avatar
How many quarts of tranny fluid in a dry TH350?
I put 11 in and it still doesn't show on the dip stick it's a 1977 swb.
crazyjim is offline   Reply With Quote
Old 03-05-2016, 11:23 PM   #2
Jeramy
Jeramy's Avatar
Re: How many quarts of tranny fluid in a dry TH350?
mine took a full 12 for transmission, cooler, and torque converter
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 03-06-2016, 11:44 AM   #3
TrailerTrash
TrailerTrash's Avatar
did you fill the converter before you put in on the tranny?
TrailerTrash is offline   Reply With Quote
Old 03-06-2016, 12:01 PM   #4
Front Range
Front Range's Avatar
Add 1 quart of fluid to the converter.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 03-06-2016, 04:06 PM   #5
Pontiac1976
Pontiac1976's Avatar
Link: http://bowtieguy.proboards.com/threa...ies-all-models
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-06-2016, 04:41 PM   #6
Jeramy
Jeramy's Avatar
i remember filling it before hand but not how many i put in it. i just remember the total being a case even. this was after a complete rebuild with new pump and torque converter.
