Old 03-06-2016, 01:02 PM   #1
Sodell
Sodell's Avatar
Vent Window paint
I have rebuilt a few vent windows and have been using automotive base and clear. I am wondering if the factory windows had a gloss finish or mat? I haven't seen an original set that was in good enough shape.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 03-06-2016, 01:44 PM   #2
1970pelle
1970pelle's Avatar
Re: Vent Window paint
Wondering the same question.
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 03-06-2016, 01:59 PM   #3
TKCR
TKCR's Avatar
Well mine where done by Precision and they don't have a clear, it's just a black finish with a very small amount of gloss to it.
Old 03-06-2016, 02:20 PM   #4
Sodell
Sodell's Avatar
I saw that they were just using a semi gloss, or matt...wonder what OEM was....matt would be easier for sure
Scott
Old 03-06-2016, 04:36 PM   #5
Pontiac1976
Pontiac1976's Avatar
Should be low luster BLK on the in side area where there where painted, the out side area was semi gloss same as inner fenders.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-06-2016, 05:10 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
I used rustoleum satin black on mine, it looks correct.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-09-2016, 08:11 PM   #7
Sodell
Sodell's Avatar
That would be a lot easier than what I am doing now.
Scott
Old 03-09-2016, 08:12 PM   #8
Sodell
Sodell's Avatar
Thank you sir for the info.
Scott
Old 03-09-2016, 10:03 PM   #9
MikeB
MikeB's Avatar
Same here.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-09-2016, 10:05 PM   #10
68Timber
68Timber's Avatar
The only downside was the dry time. I let them cure a few weeks to make sure the paint had fully hardened before I put them back together, it was just too much work to risk screwing up the finish.
John
74 Honda Z50 build
