Old 03-15-2016, 10:47 PM   #1
scoveny91
scoveny91's Avatar
XM Radio Antenna Mounting Location?
So I have this Sirius XM radio antenna for my kenwood head unit that is installed in my '57. I was wondering if anyone else has a similar antenna and where you mounted it? I want to put it in a spot that is not too noticable but still will get good reception. The base is magnetic so I can obviously just take it off and throw it in the truck when i get to shows, but it would be nice to find a good spot that i can just leave it alone. Pictures would be much appreciated!!
scoveny91 is offline   Reply With Quote
Old 03-16-2016, 03:31 AM   #2
tmoble
Re: XM Radio Antenna Mounting Location?
Glue it to the inside of the back window?
tmoble is offline   Reply With Quote
Old 03-16-2016, 05:15 AM   #3
S10Fan
Old Heap Driver
Mine is mounted (50 Chevy) in the left rear stake pocket. Bent a 90 in some sheet metal and screwed it to the inside of the pocket, ran the antenna wire through the pocket, mounted the antenna to the sheet metal, done. the reception is awesome.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-16-2016, 02:31 PM   #4
_Ogre
_Ogre's Avatar
if it works behind glass, try the back window or the corner of the dash
if not i like the stake pocket idea
shop air compressor timer
Old 03-16-2016, 04:24 PM   #5
scoveny91
scoveny91's Avatar
I tried it in the corner of the dash but it didnt seem to get good enough signal. Im assuming the glass and overhang from the roof mess with the signal. So i dont think the back window would work because the antenna would be facing inside the truck (top is rounded and bottom is flat with magnet). I do like the bed stake idea but the problem is, i dont have any stake pockets lol.
Old 03-16-2016, 06:11 PM   #6
RUN GMC
RUN GMC's Avatar
I have run them in various vehicles on the center front dash behind the windsheild has worked fine in my 98 GMC, 87 Buick Regal, and 95 Ford Explorer......but on my 87 GMC the front corner dash hasnt worked good at all a lot of dropping out when pointing north.....Im gonna the center front dash on it since it was installed by Best Buy in the front corner....but the stake bed ideal sounds like good back up......do you have any pics of it installed in the stake bed hole?
RUN GMC is offline   Reply With Quote
Old 03-18-2016, 05:14 AM   #7
S10Fan
Old Heap Driver
I'll grab a picture this weekend of the cab pocket mount. Just to add, the top of the dash on my 80 C-10 never worked properly for an XM antenna. I have a tiny area exposed on the bed rail (stepside with a tonneau cover) near the back window, works much better.
Bryan
Old 03-18-2016, 08:23 AM   #8
They need to make them for vintage vehicles. The mast could be a dummy, with the base being the 'tenny. I don't know anything about it. Justa thought.
Old 03-19-2016, 12:16 PM   #9
_Ogre
_Ogre's Avatar
not a fan of xm, i play mp3s on an 8gb thumb drive and rarely hear the same song
i'd like to see a xm antenea delete for my 09 gmc
Old 03-19-2016, 05:54 PM   #10
RUN GMC
RUN GMC's Avatar
I too play an mp3 player through mine at times.....but I like sports/sports talk that i get on the xm.......plus on the Power Tour I like to listen to sports talk in the morn till 9 or 10 then switch to all 80s/90s it makes my truck seem like a time machine while cruising.......nothing like an old vehicle with time appropriate music and the open road with a few thousand other older vehicles...
Old 03-19-2016, 06:47 PM   #11
S10Fan
Old Heap Driver
Finally grabbed a picture as requested.............
Bryan
Old 03-20-2016, 10:37 AM   #12
Highsider
Highsider's Avatar
Can the XM antenna wire be lengthened with a splice of ordinary stranded wire?
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 03-20-2016, 11:10 AM   #13
S10Fan
Old Heap Driver
The cable is plenty long. I don't think you can splice it anyway.
Bryan
Old 03-20-2016, 11:14 AM   #14
Highsider
Highsider's Avatar
Don't tell anyone, but I am thinking of a much longer vehicle than an AD or TF.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-20-2016, 11:30 AM   #15
S10Fan
Old Heap Driver
LOL
Quick check on eBay, the cables are 23 feet and an extension cable of 20 feet is also available.
Bryan
Old 03-20-2016, 01:07 PM   #16
Highsider
Highsider's Avatar
LOL
Thanks for the suggestion!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-20-2016, 03:46 PM   #17
joeydirt
Its a coax cable so its not just a matter of splicing a conductor....but you can get an RG6 adapter adapter You will also need a cox compression compression tool
joeydirt is offline   Reply With Quote
Old 03-20-2016, 04:35 PM   #18
S10Fan
Old Heap Driver
Originally Posted by joeydirt View Post
Its a coax cable so its not just a matter of splicing a conductor....but you can get an RG6 adapter You will also need a cox compression tool
Or buy this and save lots of time and money. Also. verify which cable your particular radio requires.
http://www.ebay.com/itm/Sirius-Satel...0AAOSwu1VW2h-h
Bryan
antenna, radio, sirius, xm radio
