Old 03-20-2016, 07:21 PM   #1
tucsonjwt
Washer Pump
Has anyone repaired a washer pump on an 81 and up square? My wiper motor works fine but the pump appears to be integral and not repairable. Do i need to buy the whole assembly?
tucsonjwt is offline   Reply With Quote
Old 03-20-2016, 08:05 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
Trico makes a replacement pump that bolts to the motor. I've never used one but I believe it's not gear drive like the original.
Trico # 11-515
It is possible to get most if not all the parts to re-build the gear drive pumps but they were never the most reliable pieces.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-21-2016, 05:31 PM   #3
tucsonjwt
Re: Washer Pump
I think you are correct. As I recall, I replaced the original wiper motor mostly because the pump was not working. I have replaced the plastic parts on the end of the pump before but that never got the pump working. I think I will just try to rig up a universal pump and see if that will fire up off the stock push button on the wiper knob.
Old 03-22-2016, 12:43 AM   #4
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
I believe the Trico 11-515 isn't a new gear drive unit. It's an electric pump setup to mount in -place of the gearbox and mechanical pump.
Old 03-22-2016, 02:58 PM   #5
tucsonjwt
Re: Washer Pump
How would that Trico pump mount? I don't see how the stock pump could be removed, since it is integral with the wiper motor assembly - not detachable like the 73-80 pumps.
Old 03-22-2016, 09:05 PM   #6
tucsonjwt
Re: Washer Pump
Also, when you push the pump button on the windshield wiper switch, does it send an intermittent signal to the pump mounted on the stock wiper motor, or is it continuous power of a set duration? If I use the wires to the stock pump and attach them to the universal motor, do I have to keep the button depressed to get a squirt of water, or does one press of the button give me a predetermined duration of power to the pump?
Old 03-22-2016, 09:12 PM   #7
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
The button is continuous. Power till you let go. The geartrain and cam provided the pulsing action and timer.
Old 03-23-2016, 06:39 PM   #8
tucsonjwt
Re: Washer Pump
I got a $15 universal washer pump from AutoZone. I had a little trouble identifying which wire was hot and which one was negative (ground) since my Chilton manual did not show the proper wire colors for my 83. (It turns out that on my truck pink is negative and yellow is hot.)
After wiring in the new pump and rerouting the washer lines, the pump would fire up but not pump any fluid.
So... after checking everything again I pulled the cap off the reservoir and blew out the lines.
DOH !!!
The short piece of tubing from the cap to the screen pickup on the other end was worn out at both ends, which prevented the hose from getting adequate suction, which meant that no fluid was getting to the pump. I replaced that piece of hose and it pumps very well now.
At least I don't have to listen to the "clunk, clunk, clunk" when the stock pump cam does it's thing.
While I was under the hood, I rerouted the power supply to the relay for the supplemental electric fan from the secondary start battery to the primary battery since I am not currently using the secondary battery.
Old 03-23-2016, 09:34 PM   #9
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
Glad you got it going. Too bad they integrated the motor so tightly after 1980. I remember reading somewhere that you could use a 78-80 motor on the later cabs... Maybe I'm having a senior moment too.
Circuit 93 is actually White but I bet 33 years have turned it yellow.
Pink is ground from the switch.
Chilton is a one size fits all diagram that's mostly almost but not always correct. The 1983 GM Light Truck wiring diagrams PDF in the 73-91 RTFM link below has the correct colors. I thought you'd have a hard copy.
Old 03-23-2016, 09:40 PM   #10
Pontiac1976
Pontiac1976's Avatar
Re: Washer Pump
LINK: http://bowtieguy.proboards.com/threa...-washer-repair
Trico # 11-515 is the whole pump assy. http://thumbs1.ebaystatic.com/d/l225...GnjIFAsFaA.jpg
but you can take your cover of just pop straight out ward take your
pump chamber out check the O ring if it wore out not making seal for suction.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-23-2016, 10:17 PM   #11
Pontiac1976
Re: Washer Pump
Other related troubles
now this guy sell the ground strap that falls off after many or brakes or Corrosion LINK: http://www.ebay.com/itm/190903367015...%3AMEBIDX%3AIT
LINK: http://img.photobucket.com/albums/v4...rFixesLube.jpg
Old 03-23-2016, 11:57 PM   #12
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
73-84 GM wiper motors get ignition voltage as soon as you switch the ignition to the run position. The switch grounds the Low, Hi, and Wash circuits.
Since the operation grounds come from the switch I don't believe the ground strap is needed in operation unless GM used it for additional RF noise suppression.
Does the Trico 11-515 actually fit the 81-84 wiper motors?
Old 03-24-2016, 07:28 PM   #13
tucsonjwt
Re: Washer Pump
The pump cover comes off, but the pump itself is attached to the motor assembly via a metal base crimped around the back. Earlier models I have owned had a pump removable with 3 screws, and I successfully replaced those pumps with stock GM pumps.
Same thing happened to my teeth - must be the desert heat.
Old 03-24-2016, 08:37 PM   #14
Pontiac1976
Re: Washer Pump
73-77 ground one of the three screws
Ground strap 78-84 W/Pump option on the motor. WO/ Intermittant ( delay ) 100 % sure
85-up WO/Pump on motor ( pump on bottle) not sure if they have the ground.
I be leave his was a 81
They pretty easy to work on 78-84 just do not loose the clip
Old 03-24-2016, 08:39 PM   #15
Pontiac1976
Re: Washer Pump
DOH !!!
http://67-72chevytrucks.com/vboard/a...1&d=1458772356
Looks just like the one's I worked on in the pic worked on two months ago (1984 that came with the part truck from day one @ factory works great new seals, ground cleaned) lubed gears
Old 03-24-2016, 10:09 PM   #16
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
How does adding a ground to the motor shell make any difference when the operation ground is coming from the dash?
Old 03-25-2016, 07:56 AM   #17
Pontiac1976
Re: Washer Pump
This will help your wiper transmission to park in the right place.
If you have wiper that will not park after turning off the switch, there three places to look.
Switch some times, But most times it the Ground strap there if it got a good ground there, Then it's the parking cam (gear area).78-84 wiper W/Pump on motor WO/ Intermittant ( delay ) 100 % sure
Now this if your transmission is set up in the right place to start and or wiper arms mounts(this includes trans mounts side arms) are not striped.
Old 03-25-2016, 10:59 AM   #18
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
The body ground could be an issue with parking position from 1973-1977 where there was no Park ground from the switch.
The wiper motor gets Park ground from the switch on Circuit 97 starting in 1978. The 78-91 wiper motors are not dependent on body ground for function. If they are not parking it's a problem in the motor internal switching.
Old 03-25-2016, 11:15 AM   #19
Hiluxxulih
Hiluxxulih's Avatar
Re: Washer Pump
I think I need a new washer pump motor as its about as loud as a fully loaded C5 Galaxy taking off when I need to wash the windshield .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
Old 03-25-2016, 11:18 AM   #20
Pontiac1976
Re: Washer Pump
Ok then I have to re-install the wiper check it out maybe I getting the motor's mixed up with the problems each one had.
Old 03-25-2016, 01:54 PM   #21
tucsonjwt
Re: Washer Pump
81-87 pumps look the same from the outside as the earlier pumps, but the 81-87 pumps are attached to the motor with a crimped metal base, not a screwed on metal base - at least that is the case with my 83. I guess you could retrofit a 73-80 pump to an 81-87, but I prefer my $15 solution. I have never had any luck with just replacing the plastic parts at the output end of the pump. As noted above, my only problem was a worn out pickup hose in the reservoir - I did not need a new pump, but I like my $15 pump better than the stock one.
Old 03-25-2016, 03:54 PM   #22
hatzie
Moderator
hatzie's Avatar
Re: Washer Pump
The pulsing pump and jerking wiper arms aren't what you wanted from your windshield washer?
I just swapped on a junkyard 1985 up washer tank with the pump in the bottom. Not too concerned about original looking. It might be fun to get one of the 1 gallon washer bottles off something modern where it's down in the bumper with a long gangly snorkle and then stuff it under the battery tray.
