Old 03-30-2016, 08:31 PM   #1
michael bustamante
michael bustamante's Avatar
modifying an lmc blazer tank
Have any of you guys ever modified an LMC Blazer fuel tank to work with a newer fuel pump? I want to use the one out of my 2003 Yukon. I know they sell a ring somewheres to modify fuel tanks to accept these pumps but do any of you have a step-by-step?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-31-2016, 09:51 AM   #2
JMac11
JMac11's Avatar
Re: modifying an lmc blazer tank
Yes, I bought a kit with pump and all. Just make sure when you decide where to put the pump that it clears cross braces and your fuel guage arm has full motion. I had to adjust my take placing slightly.
JMac11 is offline   Reply With Quote
Old 03-31-2016, 06:13 PM   #3
NorCalAnthony
Another memeber on here, Nasty Buzard, modified his pickup tanks to work with the newer sending unit in his build thread: http://67-72chevytrucks.com/vboard/s...=627161&page=9
Post 205 shows how he used a chunk of the donor's plastic tank to make it work and post 230 shows how the vetteworks adapter ring works. Both ways would work on your blazer tank you'd just have to figure out which newer sending unit is going to have the right/closest height to work right. Even if it's a little too tall there's a way to shorten the rods in the sending unit that's also referenced in that thread.
ps. Post some pics once you get it figured out. I'm eventually going to be doing the same thing whenever I get around to doing the LS swap on my K5 since the newer sending units have all the evap provisions I'm going to need for a CA legal swap...
NorCalAnthony is offline   Reply With Quote
Old 04-01-2016, 08:02 AM   #4
72MARIO
72MARIO's Avatar
http://www.gearhead-efi.com/gm-ecm-p...onversion.html
I have been looking at doing the same thing as a 73 up blazer jimmy or suburban tank is too long to fit in the back of a 2 wd truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-18-2016, 12:18 PM   #5
michael bustamante
yup i just ran into this same problem. now i have an 87 blazer tank doing nothing in my garage. another part to get rid of
im gonna look into these limnks now. thanks guys
1967custom
Old 04-18-2016, 11:35 PM   #6
ls1nova71
ls1nova71's Avatar
I put a fuel bucket type sender in my Blazer tank. The biggest problem with it is it needs to be recessed in the tank quite a bit, otherwise you will be hitting the cross braces in the floor or the floor itself. Lost all my pics of doing it though, so this is the only pic I have of it with the body off.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-19-2016, 05:29 PM   #7
michael bustamante
ls1nova71...thats what i was looking for. how did you recess the top of the tank like that?
1967custom
Old 04-20-2016, 10:24 AM   #8
ls1nova71
ls1nova71's Avatar
It's a piece of sheet metal bent on a brake on three sides to make a box, then it was welded into the tank. I also cut the top out of a later model tank for the ring to mount the pump which I welded to the box before welding the box to the tank.
Old 04-20-2016, 04:08 PM   #9
michael bustamante
i got the brake and the skills, what gauge sheet metal did you use? any chance at all of getting a pic of the top of the tank to see the weld location? if the beds on it, dont worry i can figure it out but i do appreciate the help!!
1967custom
Old 04-20-2016, 10:26 PM   #10
ls1nova71
ls1nova71's Avatar
I don't exactly remember the gauge of sheet metal, but it was pretty thin, probably around 18 gauge. The tank is pretty thin metal, and I tried to keep it close to the same thickness so it would be easier to weld.
It's a Blazer, and I don't have any other pics with the body off thanks to a computer virus that wiped (encrypted) all the pics I had on the SD card in my phone. But I can tell you that it's pretty much right behind the original fuel sender hole, which I am still using just for the gas gauge. I made the box part, then just trimmed the tank to fit it, then marked and trimmed the box to fit flush at the top of the tank, it's about 1 1/4" or so deep in the top of the tank.
Old 04-25-2016, 06:56 PM   #11
michael bustamante
that helps me out alot. thank you!!
1967custom
