![]() Join Date: Nov 2014
dog dish on rallies
Thought I would share how I run dog dish caps on rally rims. I know some might frown on drilling a hole in the middle of oem caps but these were pretty rough when I found them. Had them media blasted and painted dents and all. I then hand painted the black and blue which came out not bad from a distance. I found the center on the back side by xing the bowtie then drilled 1/8 hole. I used old rear axle rallie caps I had around and ripped off the 4x4 tin emblem exposing the hole in the center. I JB welded a small nut to a washer and then JB welded that to the back side of the cap. I was careful to get everything centered. I then used RV silicone to fasten 2 stacked mason jar lid gaskets on the face to take up any wobble. Once everything was dry I mounted cap on the way u normally would then i put more silicone on the out side of my gasket . I then used the smallest Robertson head nut I could find and screwed my dog dish to my center cap swishing the silicone. They are very secure with no wobble. I've had them on for two summers now with no problems. When I remove for what ever reason I just take out center screw and peel them off. Reapply silicone and touch up srew head with a dab of blue paint
Re: dog dish on rallies
More pictures
![]() Join Date: Feb 2004
Looks good.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
Scrapper 1
I have the same truck as you same paint with Chrome 3/4 caps i like running the same cap on my 1965 3/4 ton
Thanks. Had been wanting to try for a while but didn't want to wreck the only set I had . I have another set waiting for some factory 15x8 steelies someday lol.
This is brilliant; I wouldn't have thought to try this. Maybe your method will help alleviate the seeming rarity and some of the expense of obtaining the original six lug factory steelies (at least my 1970 C10 2WD) for people like me who will never run anything but a steel wheel and factory hubcap.
Great idea using the mason jar lid gaskets - those are certainly readily obtainable from any grocery store. Regarding the paint - I remember forum member Kingstrider had a great method of filling emblems with paint using a syringe; maybe that would also work on your Robertson screw to just fill up the whole recess; though of course would have to redo each time you remove the hub cap. |
If the cap is not perfectly centered and balanced, it will move around seeing as how it is only secured in that one location. This movement may eventually fatigue the plastic that the nut is secured to and send you cap flying off.
Nice job on the wheels. Sure can't beat a rallie wheel. Here is what I did with mine. 49/50 hub caps as center caps.
Nice trucks. 65 definitely on my bucket list. Funny your box is the color my truck is supposed to be and your cab and front clip is the color my truck is.
8000 miles and no signs of fatigue but your right.Do not try this at home.
#11 | |
#12 | |
Scrapper 1
I have it mocked up to be the close of the 1971-72 only years to have the 427.I found a Factory AC box for a big block out of a 1969 Nova Band new ever thing 350.00 back in 2006.Found out that the 4 door 1971-72 nova's had the same spring package as the Big block SS nova's had the same big sway Bar as well bought a crashed 1972 nova with 350 AC fully loaded for 350 back in 2007. So now i am working with this for right now sorry to steel your post I will make up on talking more on your wheels ok Last edited by stsalvage; 04-06-2016 at 09:03 PM. Reason: adding words |
#13 |
That looks darn good!
#14 |
Scrapper 1
We have to start some where and a work horse like a old truck is a good start
#15 | |
#16 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice hub cap mod, and cool Novas!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#17 | |
![]() Join Date: Oct 2009
![]() Last edited by jocko; 04-07-2016 at 09:36 PM. |
#18 | |
#19 |
Very creative-looks nice.
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
#20 |
#21 |
Looking at their website today it looks to me as if the Wheel Vintiques steelies mentioned lack the nubs to hold the OEM type dog dish hubcaps.
#22 |
The smoothies don't have nubs, but the other stock style rims do. I have a set of their 16x10 8-lug rims, and my stock caps snap right on.
#23 |
The Niner
![]() Join Date: Nov 2010
That looks wicked good. I love it!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#24 | |
#25 |
