Old 04-15-2016, 10:56 AM   #1
Dave K.
Dave K.'s Avatar
Smog Pump on 68's?
Would a 68 have had the smog pump and related plumbing in the exhaust manifolds and such? If so anyone have any good pics of this set-up? 307 V8 by the way.
Thanks, Dave.
Dave K. is offline   Reply With Quote
Old 04-15-2016, 12:07 PM   #2
cdowns
cdowns's Avatar
Re: Smog Pump on 68's?
I don't hink so as they were a few years later in mid to late 70's
Old 04-15-2016, 02:01 PM   #3
mike16
dont know about trucks but I do know that A.I.R. systems were installed on cars in California since 66. Kinda rare if you can find them complete too.
mike16 is offline   Reply With Quote
Old 04-15-2016, 02:07 PM   #4
68Gold/white
My 68 396 had an air pump on it, the under hood decal was still somewhat intact when I bought the pickup in 1980, not now though.
The air pump and associated parts were long gone when I bought it.
Not sure when and why air pumps wee installed on pickups...have not seen many pre 72's with them, though...
68Gold/white is offline   Reply With Quote
Old 04-15-2016, 02:13 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Don't know about your state and 1969 might have been different anyway but the 1/2 ton trucks in Calif. had pumps but the 3/4 ton did not have anything other than PVC.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-15-2016, 06:26 PM   #6
Dave K.
Dave K.'s Avatar
Thanks guys, looks like mine had the stuff at one time. I found a 72 locally which has all of it so perhaps I'll grab it just to save it for the future...
Old 04-15-2016, 07:16 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Yes. California vehicles had the A.I.R. smog pump system for mdl.yr. 1968. My '68 C/10 Stepside with L6 292 had a smog pump and connecting lines into the cylinder head.
I have deleted the AIR stuff and used brass plugs to fill the AIR holes in the head. Truck was Fremont built, and originally sold in L.A.
I guess on the V8s, the AIR inputs were in the exhaust manifolds. I would advise you against re-installing an AIR system. They didn't do much for air quality in reality, and were a big performance drain, and also prone to manifold leaks. Mostly a political solution.
A well-tuned engine will pass emissions without the AIR installed. Most states don't even smog test vehicles this old. Arizona does, but they don't check to see if I still have obsolete gear under the hood.
Old 04-15-2016, 10:05 PM   #8
RedRoad
RedRoad's Avatar
My brothers all original 69 C20 with 350 had a smog pump. SPID showed CA emission so it was from the factory.
RedRoad is offline   Reply With Quote
Old 04-15-2016, 10:10 PM   #9
davischevy
Post Whore
davischevy's Avatar
My dad bought a 68 new here in Arkansas, and it had a smog pump.
He went back and traded for a new 69 and it did not have a smog pump.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-15-2016, 10:42 PM   #10
FirstOwner69
FirstOwner69's Avatar
Interesting. My 69 3/4 ton, built at Fremont and sold to me in southern California did not have any emissions other than a PVC as mentioned in WorkinLonghorn's post above. My take was, as he said, that the 1/2 tons had different emissions requirements than the 3/4 tons. I always figured the emissions were driven by the GVWR. Mine's also a 350.
In response to the OP's original question. The 68 service manual has a section (6T) devoted to the Air Injection Reactor. It shows both I6 and V8 applications but does not state when it was required.
FirstOwner69 is offline   Reply With Quote
Old 04-15-2016, 11:04 PM   #11
RedRoad
RedRoad's Avatar
Does your SPID show emission line item?
Old 04-15-2016, 11:08 PM   #12
FirstOwner69
No. The engine is original (stored in my garage now). The truck was made in Dec., 1968. I bought it at Barton's Chevrolet (now defunct) in Yorba Linda.
Old 04-15-2016, 11:09 PM   #13
Dave K.
Dave K.'s Avatar
Here's why I was asking--I think the truck is a 71.
Old 04-15-2016, 11:26 PM   #14
RedRoad
RedRoad's Avatar
My brothers truck was purchased in Newhall, CA. Next time I go over Ill take a look at the door tag to see the production date and see what the dealer plate frame is.
Old 04-15-2016, 11:29 PM   #15
FirstOwner69
What in that picture makes you think 1971? The installation picture in the 1968 service manual looks just like that. Here's a link to a thread with links to the manuals. Look at section 6T.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Old 04-15-2016, 11:33 PM   #16
FirstOwner69
69s did not have door tags with production date info.
Old 04-15-2016, 11:49 PM   #17
RedRoad
RedRoad's Avatar
Good to know, is there a way to figure out production month info?
Old 04-16-2016, 12:23 AM   #18
FirstOwner69
Not that I know of without the build sheet. The VIN would at least enable a comparison with mine and help estimate earlier or later production.
Old 04-16-2016, 12:54 AM   #19
mike16
No air pumps in California cars in 66?Hmm?
