Old 04-16-2016, 08:37 AM   #1
daveklein
6 cyl carb
Hey guys I'm looking for e few good ideas....
I'm doing a rebuild job on my 67 6cyl...What do you guys use for a carb ? I am staying with the stock intake and exhaust manifolds so whatever carb I end up with will probably have to have an adaptor....I have had Zero luck with stock mono-jet so I'm looking to upgrade......I'm looking for dependable running, starting, and driving almost every day rather than high performance(and high cost).....Thanks , Dave
daveklein is offline   Reply With Quote
Old 04-16-2016, 09:56 AM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 6 cyl carb
Two barrel Rochester. You may have to re-jet it. They do make an adapter to bolt it on a stock 1 barrel intake.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-16-2016, 06:56 PM   #3
daveklein
Re: 6 cyl carb
Hey Stovebolt........Thanks for the info.. Any idea on just what model Rochester I need to look for ? Also where would I find the adaptor?
Dave
Old 04-16-2016, 07:38 PM   #4
daveklein
Re: 6 cyl carb
Looks like I found a Rochester 2GC is the one to have...and I found an adaptor on E-Bay.....I haven't bought yet but that looks like what I may need...Dave
Old 04-16-2016, 10:32 PM   #5
bretcopsey
Re: 6 cyl carb
Dave, I've got a 2GC sitting out in my shed from a 69 307 (have a hard time throwing stuff out). I'm sure it could use a clean/rebuild, but it's complete as far as I know. I'm willing to send it your way for the cost of shipping if you'd like.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 04-17-2016, 10:32 AM   #6
daveklein
Re: 6 cyl carb
Sent PM to Bret
Old 04-17-2016, 01:54 PM   #7
RichardJ
Re: 6 cyl carb
Does the truck still have the choke cable?
Have you located all the missing original linkage?
Do you have a picture of that smog Monojet mounted and did the choke actually work?
I think a 2bbl would be a bad idea. You would be throwing more money at the problem and still end up with a MacGyver'd, hacked up mess.
In your first post you said you were looking simply for drivability.
The original Rochester B will give you more reliability and drivability than anything you've been looking at so far.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-17-2016, 10:34 PM   #8
budman k20
1972 K20
Re: 6 cyl carb
I have a 6 cylinder carb from a 67 c-10 that has 49000 miles on it will that work on your truck?
budman k20 is offline   Reply With Quote
Old 04-17-2016, 10:49 PM   #9
68panelman
68panelman's Avatar
Re: 6 cyl carb
The B model carb on my 67 works great. Pull choke, starts, push in to steady idle, go back in house for five.
Drive on
68panelman is offline   Reply With Quote
Old 04-18-2016, 07:42 AM   #10
daveklein
Re: 6 cyl carb
Hey budman...I'm gonna go with the 2 barrel from Bret, Thanks
Hey RichardJ Where did you come up with those pics? It looks sorta like what was on mine when I bought it last Sept...Sweet!!!
