Old 04-17-2016, 09:25 AM   #1
72farmer
Cutting half of a coil off front spring,how to posistion in A arms?
When you cut a half of a coil off do you position spring 180 degrees from little pocket in lower a arm?If you do that of course makes the top a arm spring position 180 degrees off from its intended position.
72farmer is offline   Reply With Quote
