Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 04-17-2016, 09:06 PM   #1
lgehring
spicer pto
Good evening gents
I have a 1966 c20 4spd sm420 I think. It has been a farm dump bed since new. The cover plate on the side of the tranny needs a new gasket and seal for the pto shaft. Does anyone have the part numbers? The local auto parts stores will probably not know what i am talking about. Thanks, Lowell
lgehring is offline   Reply With Quote
Old 04-22-2016, 11:11 PM   #2
j.kirn
Re: spicer pto
Novack, or you can make your own gasket from material at your local auto parts store. You can also use silicone .
j.kirn is offline   Reply With Quote
Old 06-11-2016, 10:11 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: spicer pto
All Fel-Pro numbers
55380 standard six bolt mounting gasket
55372 .020" thickness, used for shimming
55379 .010" thickness, used for shimming
I never had to use the shim gaskets on anything I've worked on, but I guess it depends on the application.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-11-2016, 11:56 PM   #4
jumpsoffrock
Re: spicer pto
Originally Posted by Robert1970C20rstbukt View Post
All Fel-Pro numbers
If you needed a shim, shouldn't there already be one installed that you could reuse?
Thank you for the part numbers, that is the only thing that leaks on my old truck.
jumpsoffrock is offline   Reply With Quote
Old 06-12-2016, 01:36 PM   #5
Re: spicer pto
No problem. I'm not too sure, but I was told that's what those two part numbers are for. I looked on Google and it just calls them PTO gaskets.
RJD
Old 06-12-2016, 04:22 PM   #6
lgehring
Re: spicer pto
Thanks for the info ! Anybody have the number of the shaft seal?
Old 06-12-2016, 11:15 PM   #7
Re: spicer pto
You're welcome, what's the model number on the PTO?
RJD
