Old 05-01-2016, 09:27 AM   #1
7tee
7tee's Avatar
T5 Camaro Tailshaft Swap
I have an '84 Camaro (NWC) T5 and I want to change the sift location to the S10 location. The S10 I have is a '89 (WC) and I wanted to make sure I didn't have to have a S10 (NWC) tailshaft. Thanks Ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 05-01-2016, 10:02 AM   #2
jocko
jocko's Avatar
Re: T5 Camaro Tailshaft Swap
I believe your combo will work Ed. NWC and WC main cases are the same externally, only changes between the transmissions were internal to the main case. Tailshaft housings are interchangeable. I don't recall off the top of my head which year electronic speedo output came into play, I think it was in the early 90's, but that is always a consideration when choosing a tailshaft housing - older gear driven speedo output is no headache, electronic needs to be converted somehow.
Old 05-01-2016, 03:29 PM   #3
7tee
7tee's Avatar
Hey jocko have you heard anything about the oil flinger in the 1989 (WC) S10 tailshaft not wanting to fit into the 1984 (NWC) Camaro? Looking at the H.A.M.B. jalopy journal site, page 3, by "bobscogin" mentioned this situation and said it would need to be a (NWC) S10 tailshaft. Have you done this swap or know of anyone who has before I pull the S10 out of the truck and take chance? Thanks again Ed...
2010 Acura RL...
Old 05-01-2016, 08:46 PM   #4
Lugnutz65
Lugnutz65's Avatar
Hello, just visiting from the 60-66 section.
Here is some handy info:
Camaro and Firebird NWC T5 = 1983-1987 (Muncie pattern case)
Camaro and Firebird WC T5 = 1988-1992 (Muncie pattern case)
Camaro and Firebird 1993 and up are also WC but have a Ford case.
S10, Sonoma & S15 trucks NWC T5 = 1983-1992 (Muncie Pattern case)
S10, Sonoma & S15 trucks WC T5 = 1993 (Muncie pattern case)
S10, Sonoma & S15 trucks 1994 and up are also WC but have a Ford case.
Your 1984 NWC Camaro will mate up with the 1989 NWC S10 tail just fine.
As food for thought. if you rebuild the Camaro T5 using the S10 main shaft instead of the Camaro main shaft, then you can keep the VSS and use an electronic gauge. It really all depends on what you want to end up with.
If you have a V6 Camaro then swap out the input shaft for a Jeep input shaft and eliminate the need for a spacer plate. LINK
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-02-2016, 07:27 AM   #5
7tee
7tee's Avatar
Great news, thanks for all the info...ed...
2010 Acura RL...
Old 05-02-2016, 11:07 AM   #6
69rut
You will most likely need to change the speedometer drive gear location on the tailshaft. The gears usually have a clip holding them in place with a hole in the tailshaft as well. You can not drill a new hole and the shaft diameter is smaller where the gear needs to be positioned. Best bet is to shim the gear and use some J-B Weld to hold it all in place.
trailers are for boats
69rut is offline   Reply With Quote
Old 05-02-2016, 11:45 AM   #7
Lugnutz65
Lugnutz65's Avatar
His 1989 S10 tail shaft housing has a VSS sender. He cannot make the Drive gear work unless he finds an S10 tail housing with cable connection. If he finds one of those, then your advice is correct.
