![]() Join Date: Sep 2001
Temp gauge wire routing
What is the correct/best routing of the green/insulated temp sensor wire from the firewall to the terminal? Photos may help! Thx
![]() Join Date: May 2010
Re: Temp gauge wire routing
The original routing was in a fabric loom along the valley formed by the left valve cover and intake manifold. My original 350 left valve cover had a couple retainer clips for attachment. At the front, it dropped down to a clip retained by the bottom water pump bolt/stud then back and up to the temperature sensor.The pictures below show the routing. In the second picture the bolt/stud is in the wrong (top) hole.
EDIT: Added 3rd pic. Last edited by FirstOwner69; 05-14-2016 at 09:03 PM. |
