06-10-2016, 10:02 PM | #1 |
looking at a 70 4x4
It's cheap. It has a title. It has a stretched frame 4-6 inches with a plate and welded. Owner thought it might have had a dump bed on it. It is 200 miles from here so 4 hour drive one way. I may need this as my 71 4x4 frame and running gear were stol . . . . I mean disappeared. Blown motor, no transfer case or 4 speed. I have most of the needed parts from my 71. I am sure I could part it out and make money and keep the frame. but the stretched frame bothers me.
Your thoughts. Its cheap enough i will probably go after it as I need a frame bad. |
06-10-2016, 11:03 PM | #2 |
Re: looking at a 70 4x4
Parts is parts
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
06-11-2016, 02:56 AM | #3 |
You can swap the parts over to a 2wd frame its a lil work but its been done.Is anything wrong with the frame you have now ?
06-11-2016, 07:40 AM | #4 |
People cut and weld frames often. If you're gonna put an original bed back on you'll have to recut the added section out, and then you can have whoever you want, or yourself, weld it and not worry ya know.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
06-11-2016, 02:19 PM | #5 |
andrewmp6: The biggest problem with my disappearing frame is I have no idea, well I do have a strong suspicion where it might be but no proof.
74CustomK20: Pretty sure that is the route I will be taking. Just needing to think about it longer and get others thoughts. I don't weld, about all I can do is turn wrenches, put on parts, and do as I am told. I do have patience. Thanks for the replies |
06-14-2016, 03:55 PM | #6 |
Going to pick it up tomorrow, only have seen pictures.
It hit me last night as I was not sleeping good to look for a flat bed for this truck rather than just jump in and shorten it. Ill look for the other parts it needs before I make up my mind. |
