napco 4x4 axle parts c-60
I have a set of napco axles from a 67-72 body style c-60 . there 5/10 lug with the 8.25-20 tires .
looking to fresh them up with possible brake parts and I know seals and gaskets . were is a good place to dig up 4x4 front axle stuff for these ? cast in the housing long side tube is napco 38508 if I read it correctly . also might be needing for t-case gaskets and seals . maybe some small parts . any info on these ? have not found a tag on it yet . it has a parking brake on the back side . and twin shifter stick for high/low and front in/out. can and will post pics Monday .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Re: napco 4x4 axle parts c-60
looks like a Rockwell t223 tcase from searching and info with pics I have found.
it also has a ramsey pto unit out the top on back .
Gaskets can be made and, usually, seals can be matched up. Not sure where to get started looking for parts, other than truck axle/bearing service supplier. In Baltimore I would check with a place called Trans Axle.
https://www.google.com/url?sa=t&rct=...naAGU_ek3CfTsg
few pics of parts
| Bookmarks |
