Throttle Bracket with Bowtie Overdrives Trans Bracket
I've got a 69 with a 700R4 I'm moving to my 71. The 69 has a solid rod for the throttle linkage, and the 71 has a cable. My problem is that the Bowtie Overdrives plate that goes under the carb and contains the trans linkage puts the transmission linkage in the same spot that the 71 throttle cable would go. I'm looking for some king of bracket that would hold the throttle cable above where the trans cable goes.
Anyone run into this before? Did you fabricate a bracket, or find one at an aftermarket shop? Bowtie Overdrives tells me they don't have one for this application.
Stan Feldsine - Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=673856 1969 C10 LWB Fleetside - 350 - 700R4 1971 C20 LWB Fleetside - 350 - TB350 |
| Bookmarks |
