Old 08-01-2016, 08:57 PM   #1
FLA_Instigator
Arrghh... memory leak
I can't recall the name for the metal plate that attaches on the top of the radiator and extends over the fan. I have searched all combinations of words I can think of and am drawing a blank...
Thanks!
FLA_Instigator is offline   Reply With Quote
Old 08-01-2016, 09:04 PM   #2
geezer#99
geezer#99's Avatar
Re: Arrghh... memory leak
Fan Shroud!!!
Old 08-01-2016, 09:53 PM   #3
FLA_Instigator
I tried that and it isn't the part I am thinking.... the part I am thinking of is maybe 18"x18" and takes 2-4 bolts. When searching on "fan shroud" I get this stuff... If I had my truck here with me I would take a pic.
http://www.classicindustries.com/sho...nents/shrouds/
Old 08-01-2016, 10:17 PM   #4
cmo71
cmo71's Avatar
Are you thinking of a radiator top plate or radiator support panel?
Similar to this? -
https://www.opgi.com/common/C980152-lrg.jpg
cmo71 is offline   Reply With Quote
Old 08-01-2016, 10:27 PM   #5
71swb4x4
71swb4x4's Avatar
Are you sure it's not a fan shroud, AKA finger guard, for a 6 cylinder? Like this picture:
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-01-2016, 10:32 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Try METAL FAN SHROUD Only used on the 6 cylinder manual trans trucks if I remember correctly....
LockDoc
Leon
Old 08-01-2016, 10:47 PM   #7
FLA_Instigator
THANKS!!! that's it. I have scoured hundreds of photos looking for this thing. I guess what is curious is that my truck has a 305 but does have the shroud (guessing the PO added it).
much thanks! I can sleep now.
Old 08-01-2016, 11:19 PM   #8
70cst
70cst's Avatar
Thanks guys for a job well done
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-02-2016, 08:02 AM   #9
engineer_gregh
engineer_gregh's Avatar
I would check the VIN FLA_Instigator. If it starts with CS versus CE, your truck was originally a 6 cylinder not a V8, thus the finger shroud.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 08-02-2016, 09:13 PM   #10
firedemon
I like this one in the middle for an 8 cyl rad gives it a more finished look I think . I bought it but it didn't fit my l6 rad too wide so I made one out of stainless now I have the 8 cyl rad I put the one I bought on
firedemon is offline   Reply With Quote
Old 08-02-2016, 09:14 PM   #11
firedemon
oh and I think with the core filler panel it should help more air go through the rad instead of over
Old 08-03-2016, 10:42 PM   #12
FLA_Instigator
Thanks, I'll look into that. Engine compartment is next on my list of things to get in order.
