08-11-2016, 02:50 PM | #1 |
which frame
As titled I'm wondering which frame I have, was told it was early 70's frame this is 4x4 btw,my truck when I bought it was a 64 sitting on an early 70's, But I need to know exactly which yr as I'm considering a lift and don't want to order the wrong one, I saw some #'s on the right front toward the spring hanger mount the last # was 70, so can I assume that it's a 70 or do I need to measure the spring width or length of springs, any help would be greatly appreciated...this is a Frankenstein truck...LOL......................
1964 BBC 402 4x4 |
08-11-2016, 04:31 PM | #2 |
6>8 Plugless........
Re: which frame
Can you post some pictures so we can try to help you? How about some leaf spring measurements? The 72 and down have shorter front springs than the 73 ups. The pre 72 frames are also narrower than the 73 up frames.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-11-2016, 10:29 PM | #3 |
Re: which frame
hope this helps...the front end partially disassembled...
when I first got the truck someone had cut straight into the frame horns and split them don't know they did that but I cut them off so I could use the 64 frame horn to mount my bumper...I'm trying to think how they looked when I cut them off...anywho I still believe it's 70-72 frame...the truck does have disk brakes so I know they didn't have them until 71-72...
1964 BBC 402 4x4 |
08-12-2016, 03:20 AM | #4 |
Re: which frame
The strap on the front of the driver side leaf makes me think it is a 72 and earlier frame. Is there a Vin number stamped into the frame near the steering box?
08-12-2016, 07:41 AM | #5 |
Re: which frame
I agree 72 and earlier, but to double check just measure the mounting holes and call where you wana order from.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
08-12-2016, 07:27 PM | #6 |
Re: which frame
Yea that a good indicater with the strap across the left front spring hanger...I should've noticed that myself...
1964 BBC 402 4x4 |
08-12-2016, 08:04 PM | #7 |
Re: which frame
72 bump stops were bolted in like yours. My 1970 bump stops were held in by the rubber. However the sway bar appears to be of 73 or newer type with mods to make it work. Need pics of the whole truck though! Just because we like pics!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-12-2016, 08:55 PM | #8 |
Re: which frame
Yea the sway bar was added by the P.O. and pretty sure my bump stops are bolted on...I know when you order the lifts that there always from 69-72 so I should be safe with that...Boy I had my hands full or should I say truck full my son got a project truck an
82K20 and I hauled it home yesterday...
1964 BBC 402 4x4 |
08-13-2016, 02:58 AM | #9 |
Re: which frame
Would there be a vin on the frame with it being that old ?
08-13-2016, 09:03 AM | #10 |
Re: which frame
Oh I should have said that the 64 body is on an 4x4 chassis this is a Frankenstein truck..I recently went from a 292 six to a 402 BBC...
1964 BBC 402 4x4 Last edited by RANDY COX; 08-13-2016 at 09:06 AM. Reason: added more pixs |
08-15-2016, 03:39 PM | #11 |
Re: which frame
Very nice engine swap! I'm pretty certain that only 1972's had that strap on the front hangers. (I could be wrong though)
08-15-2016, 04:27 PM | #12 |
Re: which frame
My 65 C10 has the vin stamp in the frame, in fact I think I see it in this pic.
Dont think GMCs had frame vins on early trucks though |
08-19-2016, 08:35 PM | #13 |
Re: which frame
I'll have to check that area I haven't really noticed...
1964 BBC 402 4x4 |
08-24-2016, 11:30 PM | #14 |
Re: which frame
Hey Randy, I really like the painted front frame and firewall. What did you use to paint with? Rattle can or spray gun? Im at that point with the '63 and am not really ready to bite the bullet on a spray set up.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
08-26-2016, 08:52 PM | #15 |
Re: which frame
Hey everything was rattle can I sanded everything down and primered with rattle can too..
1964 BBC 402 4x4 |
09-03-2016, 12:20 PM | #16 |
Re: which frame
Man that turned out nice. Ive been debating rattle can engine paint vs rattle can automotive paint (that I can get at my local Napa) for a while. You may have just helped me make my decision.
09-05-2016, 09:39 AM | #17 |
Re: which frame
Randy if you have a 72 short wheelbase frame, this would be the direction I'd be heading.
09-05-2016, 10:02 PM | #18 |
Re: which frame
I hear ya there, I had a 4x4 suburban of that era, I wanted a 60's 4x4 and that's when I found this truck..
1964 BBC 402 4x4 |
09-08-2016, 09:01 PM | #19 |
Re: which frame
73 and newer frames the rear shocks are on opposite sides of the rear axle.
09-11-2016, 03:46 PM | #20 |
Re: which frame
Oh ok Mudder, I'm pretty sure that there both are mounted on the same side...
1964 BBC 402 4x4 |
09-11-2016, 08:27 PM | #21 |
All about them K’s
Re: which frame
Looks like a 72 frame to me. definietly looks like a 67-72 frame, the front frame horns that are still attached to the bumper look like 67-72 horns.as said before with the spring stops and open knuckle disk breaks I'd say 72.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
