Old 08-18-2016, 05:45 PM   #1
Chrispbrown36
U-Joints
Looking over the selection of u-joints offered for my truck (87 V10) is dizzying. Moog alone offers 11 different part numbers. That just doesn't seem right....there aren't 11 different u-joints on the truck! Some are listed as "premium" and some "super strength". Is there really any difference between the two? Also, why would GM not use the same u-joint at all points where one was necessary? It just seems like a waste of money to have to order or manufacture different joints for different points on the same truck.
Chrispbrown36 is offline   Reply With Quote
Old 08-18-2016, 05:54 PM   #2
Nick_R_23
Nick_R_23's Avatar
Re: U-Joints
Many times the differences are low vs high quality steels or manufacturing tolerances, or simply greaseable vs non-greaseable.
Old 08-19-2016, 07:30 AM   #3
GRX
GRX's Avatar
Re: U-Joints
^^ that. Plus different end cup diameters depending on application. 1-1/16' vs 1-3/16" for instance.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-19-2016, 07:36 AM   #4
77 ChevySport
Re: U-Joints
FWIW: When we replaced the original U-Joints on my 77 Shortbed Sport it was a nightmare ordering them from Chevrolet. Their parts book had 3 solid pages of different U-Joints for their pickups. Due to the variety of different options and GVW of the trucks is why there is so many different types. Also some trucks have the center bearing(mine has this)and different rear ends which require more U-Joints which complicates the ordering. Take it from me:
"ORDERING/FINDING U-JOINTS FOR PICKUPS IS 10 TIMES AS CHALLENGING THEN ORDERING THEM FOR CARS"! Larry
77 ChevySport is offline   Reply With Quote
Old 08-19-2016, 04:49 PM   #5
akart
Re: U-Joints
Go to a shop/parts place like here in Fairbanks Alaska there is Young's Gear and Drive line. They fix vehicales in the shop and sell parts. Tell them what you've got and they hand you the part,the right part.
Think my last one was a Spicer for about 25 bucks.
In other words go to a speciality shop.
akart is offline   Reply With Quote
Old 08-21-2016, 09:53 PM   #6
MikeB
MikeB's Avatar
Re: U-Joints
I have used a local driveshaft shop twice in the last few years. Straighten, balance, and 2 new USA-made u-joints for $100 parts & labor.
If your truck has the original u-joints, I hope they weren't secured with melted plastic instead a metal retainers, because it's a PITA to get the caps off.
Here's some good info on u-joint sizes. Seems like my 82 C10 used 1310 or 1330. As I recall, high performance and maybe 3/4 ton truck applications use 1350.
http://www.fourwheeler.com/how-to/13.../photo-02.html
http://www.driveshaftspecialist.com/...D%20Guide.html
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-21-2016, 10:52 PM   #7
GRX
GRX's Avatar
Re: U-Joints
The injected plastic is actually quite easy to deal with when some heat is applied. Have done more than I care to remember.
Old 08-22-2016, 03:03 PM   #8
Ski-me
Ski-me's Avatar
Re: U-Joints
If it's a half ton truck, most likely it will be either a GM 3RL or a 1310.
I would go with Spicer joints. Most common and reliable.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
