Old 08-23-2016, 11:03 PM   #1
truckin 79
Leaf spring junk yard removal
Anyone have advice on taking leaf spring off in junk yard quickly and easily? I already tried bolts but U bolts are stuck solid. The eye bolts seem a little sketchy crawling under truck. The truck at j-yard is already lifted off the ground supported by rims. I just need one
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 08-23-2016, 11:10 PM   #2
Rubble
Re: Leaf spring junk yard removal
Never done a junkyard removal,but at home I always just use a zip wheel on U bolts & shock bolts,bolt cutters on E brake cable & lines if not reusing them & once axle is out,zip wheel Center bolt & there's your leaves. A small generator would be your friend in the junk yard.Fighting wth old Rusted U bolts isn't much fun.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 08-23-2016, 11:49 PM   #3
bbbc10
Diggin The SquareLife
just use a cut off wheel to cut the u bolts and front and rear bolts...
bbbc10 is offline   Reply With Quote
Old 08-24-2016, 07:04 AM   #4
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
I just took my Kobalt cordless impact, breaker bar (just in case), and some PB blaster. I sprayed all of the bolts then walked around the yard looking for about 30 minutes. Cordless impact did the job, no problem.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 08-24-2016, 07:36 AM   #5
chrismoore701
chrismoore701's Avatar
cordless sawzall
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 08-24-2016, 10:44 AM   #6
Dead Parrot
Check with the yard on their power tool policy. Some don't care, others don't allow. All it takes is one idiot trashing several hundred dollars worth of body parts trying to recover a $10 emblem to make yards hate power tools.
Or you may get lucky and the yard has tools they will let you borrow.
+1 on the penetrating oil. Even WD-40 will help. See if the yard will reserve the leaf pack for you and give everything a good soaking and come back the next day.
Consider getting both sets. The sag on your existing set may be different then the JY set.
Dead Parrot is offline   Reply With Quote
Old 08-24-2016, 05:41 PM   #7
truckin 79
Well I do have a ryobi sawzall and a impact driver that I could probably make work. Maybe I can sawzall the eyelet bolts at the shackles and hopefully impact is strong enough to get bolts off. I have a cracked spring on one side because someone decided to add lift blocks and the stress cracked leaf spring. I do need U bolts now that I think of it since the others are too long now. I will see how easy it is to get one off and if it is easy enough maybe 2.
Thanks for help
