Old 08-25-2016, 06:33 PM   #1
pphil
?'s about going carb on my 94 gmc
tired of fighting with my truck
(electrical gremlins)
are there any down side to changing to a carb
i have a 5 speed so i dont have to worry about the trans
and we have no emissions testing
scott
1994 GMC 2500 4x4 extended cab long bed
5.7 5 speed
1970 wildcat
455-4
pphil is offline   Reply With Quote
Old 08-25-2016, 08:23 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: ?'s about going carb on my 94 gmc
Pretty much everything you can think of......
Carbs suck. End of story.
Old 08-26-2016, 06:33 AM   #3
pphil
gee thanks
every carbed engine i have runs great
but this truck........not so much
i just want to be able to drive my truck
i had a new engine installed
and they left the ground straps off the engine
(been replaced)
any help would be appreciated
scott
5.7 5 speed
1970 wildcat
455-4
Old 08-26-2016, 10:06 AM   #4
rickpilgrim
If you want to go back to carb you can but will need lots of little things like:
A new throttle cable, you can get a universal one from O Rielly's that works.
A centerbolt valve cover intake manifold, aftermarket preferred
A carburetor, a rebuilt Q jet would be best or a 600 CFM Edelbrock
You will need a adjustable return style fuel pressure regulater set around 5 psi
Your guage wires will be the same but you have to seperate the wiring of those from the ECM wiring and prune the TBI connections out( be careful not to cut out the oil psi/fuel pump relay circut)
And a Chevy HEI distributor to run the spark side but be aware I have not been succesful hooking a factory tach to an HEI system as of yet so your tach may be gone.
There may be some other little things I missed.
rickpilgrim is offline   Reply With Quote
Old 08-26-2016, 10:09 AM   #5
rickpilgrim
and the bulb for the check engine light needs to be removed also
Old 08-26-2016, 10:18 AM   #6
Marshy
Holley offers an inline electric fuel pump that supplies 4psi. Look up Holley Mighty Mite pumps on summit. They are perfect for a mild 350 and an Edelbrock 600cmf carb. Max fuel psi for the Eddy is 6psi but the manual says to set the regulator (if you have one) to 5.5 psi. You could probably use a throttle cable from a late C or K series truck. Mounting bracket you'll have to figure out though.
You would need the 8 bolt intake manifold like mentioned. Edelbrock Performer 2116 is what you are looking for. They can be had on Craigslist for around $100.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 08-26-2016, 05:10 PM   #7
pphil
thanks everyone
scott
5.7 5 speed
1970 wildcat
455-4
Old 08-29-2016, 05:04 PM   #8
Tom
Tom's Avatar
gee thanks
You asked?
Converting to carb is not very hard, but the drawbacks compared to a properly running EFI system are numerous. Was 94 a TV cable 700R4 or a 4L60e? Not sure how converting to carb with the 4L60e works honestly.
Old 08-29-2016, 06:42 PM   #9
pphil
You asked?
i don't know the answer to that question
as mine has the nv4500 5 speed trans
if i could get the tbi to run properly i would leave it alone
i assume i will lose my cruise/tach/and maybe the gauges
i can install gauges an tach aftermarket
my speedo is already bouncing all over the place
and it is running so rich my eyes are watering
scott
5.7 5 speed
1970 wildcat
455-4
Old 08-31-2016, 05:34 PM   #10
Tom
Tom's Avatar
Speedo bouncing is either a cable if they still use them on your year or a sensor in the trans.
Cruise is controlled with a cable just like the throttle so you might be able to rig something up to work.
Personally I'd rather spend the money somewhere good like an oem dealer and get the fuel injection fixed. TBI is a very simple system as far as fuel injection goes.
Old 09-01-2016, 09:32 AM   #11
rickpilgrim
If it's running very rich the TBI system is in limp home mode and not receiving data from critical systems. A properly working O2 sensor is a must and the coolant tempature sensor is critical also. These parts are more cost effective than going carb and do keep in mind we spent a fair amount of time changing jets and metering rods and reading spark plugs as no out of the box carb will be spot on.
Your speedometer should be electronic and it sounds like you have a bad sensor or loose wires/plug going on.
Point is our junkyard jem Dodge ran like yours and we just replaced the O2/coolant temp/map sensor/throttle tps/ fuel pressure regulator and cap/rotor/wires and plugs. $262.41 on Amazon for all that and it runs perfect.
$263.00 is not going to go far converting to carb.
