08-26-2016, 06:31 PM | #1 |
Need Help! 3/4 Ton rear disk brake conversion
I've been searching here and on other sites about converting my 78 K20's rear drums over to disks and the more I read the more confused I'm getting. I found a bracket kit from Off Road Design but like most of these bracket kits you need to add a drive shaft brake or similar which is something I'd like to avoid. I'm also given to understand that one can use eldorado calipers and maintain their e-brake which sounds good until you realize that these things are expensive in comparison to regular calipers. I'm also understanding that I could swap out my corporate 14 bolt with a newer AAM 10.5 or 11.5 and gain back the e-brake but will have to re-position the spring perches.
So far, am I correct in these assumptions? Have I missed anything? Any suggestions?
1980 GMC Sierra Grande C15 1987-1992 1988 Chevy Silverado K1500 1992-1996 1978 Chevy K5 Blazer 1998-2002 1998 GMC Sierra SL K2500 2002-2010 2007 GMC Sierra Classic 2500HD LBZ 2010-Present 1978 Chevy Silverado K20 2016-Present |
08-27-2016, 03:07 AM | #2 |
Re: Need Help! 3/4 Ton rear disk brake conversion
Just make sure that rear axle is 2010 and older,2011 they changed the bolt pattern to metric.
08-27-2016, 11:37 AM | #3 |
Anyone ever hear of Right Gear & Axle? They make an adapter plate that will allow you to mount the backing plate, e-brake, hub & brake assembly from an AAM 10.5 or 11.5 on a GM Corp 14 bolt FF.
08-27-2016, 02:54 PM | #4 |
Hollister Road Co.
I called them several times to get some but they seemed less than interested in making anymore. I even asked if I could buy the cad file and they didn't have one saying someone else makes them for them.
We decided to make our own for the HO52/72 axle. I'm not sure ours will work on a early 14 bolt but the housing end looks the same on the HO axles. I suspect it will need a different rotor than we use. Take a look at this and see if your interested in working with me to make a kit for the swap. This is for the HO axle with slide on drums https://www.hollisterroad.com/HO5272Eaton.php |
08-27-2016, 08:38 PM | #5 |
If you can still get them i say go for it.
08-30-2016, 12:15 AM | #6 |
I ordered a bracket from blue torch fab years ago and just installed a line lock valve to rear brake line to use it as an emergency brake can get u pics tomorrow of my set up if needed it's on a 14 bolt rear they make bracket s for any rear
08-30-2016, 08:22 AM | #7 |
Id like very much to see pics of this!! It sounds like a good alternative to expensive calipers. Id like to see pics of how you activate it in the cab as well. Thanks.
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
