Old 09-12-2016, 03:41 PM   #1
TJ's Chevy
TJ's Chevy's Avatar
Is this piece of clutch linkage available?
Hey guys, I am either going to have to repair this or purchase a new one if they are available....so that leads to my question...what's the best way to repair this? I know...fill weld it and grind smooth....which I am terrible at. haha Are new ones produced? As you can see from the wear...I doubt it will last a very long time under the load of a new pressure plate.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-12-2016, 04:28 PM   #2
1963c-10
1963c-10's Avatar
Re: Is this piece of clutch linkage available?
pretty sure I have one sitting on the extra parts shelf TJ. Ill check at 6pm my time and let you know tomorrow. Just cover the postage and its yours. I have a complete assembly from a friend who converted from manual to auto.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-12-2016, 06:40 PM   #3
Blue666(2)
Can you get a more clear picture?
I was looking here but could not find it. Lots of other good stuff.
http://www.amkproducts.com/default.htm
Blue666(2) is offline   Reply With Quote
Old 09-12-2016, 06:44 PM   #4
Blue666(2)
Check on page 313 & 314. See if those descriptions are what you need.
http://www.amkproducts.com/Catalog_PDF/308-402.pdf
Old 09-12-2016, 07:13 PM   #5
Haaland
I also have one, I won't be needing anymore when I do my swap. Same deal postage and it's yours.
Haaland is offline   Reply With Quote
Old 09-12-2016, 09:26 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Thanks man! If it's in good shape SOLD! lol!
Old 09-12-2016, 09:27 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Thanks for the links! Took a look, but they only have the rods and bushings. Not this piece that I could find...course I don't even know what it is supposed to be called. lol Will have to look in the manual.
Old 09-12-2016, 09:28 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
Thanks man! PM sent.
Old 09-14-2016, 07:10 PM   #9
1963c-10
1963c-10's Avatar
Here's the pics tj. Can have the whole rod assembly or I'll ship just the fitting.....Up to you
Old 09-14-2016, 08:44 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Just the fitting would be awesome. Let me know on shipping. Thanks!
Old 09-14-2016, 09:42 PM   #11
padresag
You can buy them new
ron
padresag is offline   Reply With Quote
Old 09-14-2016, 09:46 PM   #12
padresag
over 8,000 posts on here and you would think he would look here
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=89
ron
Old 09-14-2016, 09:50 PM   #13
jtrichard
No o fence but that one don't look any better than the one you have i would braze yours up or get a new one
jtrichard is offline   Reply With Quote
Old 09-14-2016, 10:57 PM   #14
1963c-10
1963c-10's Avatar
The pic does it no justice. Other than grease and dirt it's a solid piece. Pic taken in the barn while dark. It's also a free part that I'd comfortably run with no problem.
Old 09-14-2016, 11:00 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
Never ordered from LMC so I never checked.
63C10: I noticed it looked worn out, but since I don't have any spares I figured a couple to keep in the glove box just in case is better than none at all! haha But you mentioned it's solid so that's awesome.
Old 09-14-2016, 11:11 PM   #16
TJ's Chevy
TJ's Chevy's Avatar
After checking Orange County truck and car shop, Classic Parts of America, Napa, and O'reilly auto I didn't think to check LMC so I checked here. Thanks to all those for Helping rather than make a big deal about it.
Old 09-15-2016, 01:12 AM   #17
padresag
truck and car shop https://issuu.com/truckandcarshop/docs/ts_60-72_web
bottom page 127
ron
Old 09-15-2016, 08:49 AM   #18
1963c-10
1963c-10's Avatar
Pm me your address TJ and I'll mail it to you. You won't have any issues with it. Any other clutch linkage parts you need?
Old 09-15-2016, 01:33 PM   #19
61K10
61K10's Avatar
Is the notch suppose to be in the round shaft?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-15-2016, 01:35 PM   #20
TJ's Chevy
TJ's Chevy's Avatar
According to the pictures of new ones I don't think so. Due to the fact those parts are never lubed the notch would appear after many years of use....Heck they lasted 50 years! lol I am sure it would last many more to, but rather have new. haha
Old 09-15-2016, 01:36 PM   #21
padresag
that is wear
ron
Old 09-15-2016, 04:36 PM   #22
thunder71
thunder71's Avatar
I'm a welder and see a easy repair on that part...weld it and file it back to shape.
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 09-15-2016, 04:59 PM   #23
1963c-10
1963c-10's Avatar
The notch looked machined flat....if its from wear, I would replace with a new part for $13. I will try and get home before dark and get better pics and relook at it.
Old 09-16-2016, 08:13 AM   #24
1963c-10
1963c-10's Avatar
I looked at the part again last night TJ and I have to agree with the forum. Downside of a dark barn.....the part does have a groove worn into it. With that being said, I have no problem shipping it if you still want it. It has been mentioned that it is an easy fix, but the option is your to decide. Just let me know.
Jon
Old 09-16-2016, 08:35 AM   #25
padresag
that will more than likely not be the only piece that needs welding. the holes that the linkage ends go in are also worn as are the other linkage ends. this has all been brought up more than once.
ron
