Old 09-20-2016, 01:58 PM   #1
matthamby
Question - Saddle Gas Tank In a 70 C10?
Hey guys!
I have been wanting to for a while relocate the gas tank from the cab to under the bed, however, putting it where the spare tire goes isn't an option, I want to use my truck like a truck, and that means the spare needs to be stored in the proper place. I have found an 86 C10 gas tank, it is a saddle tank. from what I can tell, it appears like it would work on my frame (by using the 86 factory straps & boring mounting holes into my frame, etc...). I also plan on getting the necessary items to install a door in the side of the bed, like most modern trucks. Has anyone attempted this? Does anyone know if this is viable?
All I have been able to find involves putting the tank in the rear of the bed, that's just not appealing to me.
Thanks for any help!
Matt
matthamby is offline   Reply With Quote
Old 09-22-2016, 04:03 PM   #2
matthamby
Re: Question - Saddle Gas Tank In a 70 C10?
no one?
Old 09-22-2016, 10:21 PM   #3
I'm pretty sure it won't work. Have you figured on how it will fit up under the cab? '73-ups have a raised floor under the seat.
Pickups:
https://www.google.com/url?sa=i&rct=...74683513844147
K5:
https://www.google.com/url?sa=i&rct=...74683585935088
Old 09-22-2016, 10:28 PM   #4
custom10nut
custom10nut's Avatar
Special K is correct. The cabs are very different
custom10nut is offline   Reply With Quote
Old 09-22-2016, 10:49 PM   #5
matthamby
The idea that I'm kicking around is to pipe it to the side of the bed ala modern style, the fitment was the answer that I was looking for, thanks guys
Old 09-23-2016, 12:31 AM   #6
El Dorado Jim
I used the old" travel tanks",which were aftermarket tanks for our old trucks, you can still find them on this forum for sale or on craigslist sometimes, I mounted them underneath then took out the seat tank
El Dorado Jim is offline   Reply With Quote
Old 09-23-2016, 08:25 AM   #7
matthamby
Thanks!
I had found this 86 tank on craigslist, it has all the pump & sending unit etc... for $50. I wanted to see if it could work for what I needed. I've seen the Camper/ travel tanks in other trucks, but I haven't seen any that were available. Oh, well, back to the search!
