Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-29-2016, 09:02 PM   #1
c-man405
12 bolt confusion
After breaking a drive shaft/u joint/yoke last week at the track I decided to open up the rear end and make decisions on what to upgrade. Inside I found a part number ydggm12p-3-30 on the carrier which is a Yukon gear and axle 500 dollar posi unit
The confusing part is that part number is for a car 12 bolt not a truck 12 bolt? So do I need a car ring and pinion or a truck ring and pinion? I know I need truck axles because of the larger bearing size but will the work with the car posi?? Honestly much like transmission I don't know anything about rear ends so any help would be great!
Thanks Carter
c-man405 is offline   Reply With Quote
