Old 10-02-2016, 02:29 PM   #1
kevmic28
kevmic28's Avatar
Brake shoe anchor
My son snapped the brake drum anchor pin bolt on his truck. I have searched online and cant find a replacement. I can find one for chevelle and Camaros but none for the c10. Any idea where I can go to find one or anyone have one laying around?
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 10-02-2016, 03:41 PM   #2
jescates
jescates's Avatar
Re: Brake shoe anchor
Any parts store, just tell them you need a drum brake hardware kit for your model year. I think I got my kit from Autozone for 10 bucks, has all the hardware including springs.
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 10-02-2016, 04:47 PM   #3
kevmic28
kevmic28's Avatar
You would think. But no not this part. This bolts to the backing plate. Here is a picture of the broken pin.
1970 GMC truck
Old 10-02-2016, 05:18 PM   #4
GR8-68
GR8-68's Avatar
I have a couple of them if you can tell me how to get them out
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-03-2016, 12:16 PM   #5
BILT4ME
Aren't they part of the backing plate? The easiest and fastest would be to get a replacement backing plate from a like vehicle.
Remove the rear diff cover
Remove the C-Clip
Pull the axle
Pull the seal/bearing
Unscrew the brake line
Remove the wheel cylinder
Unbolt the backing plate.
Install is reverse.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 10-03-2016, 03:37 PM   #6
Wrenchbender Ret
Some of them have a large nut on the back of the backing plate. If so, remove this nut & tap out the anchor pin. You should be able to find one at a salvage yard. If it is built in to the plate you will need to replace the backing plate.
Wrenchbender Ret is offline   Reply With Quote
Old 10-03-2016, 04:12 PM   #7
BILT4ME
You're right! Now that I look at the picture he attached again, it looks like his may be the "nut" version.
Howdy neighbor!
1970 GMC K2500
Old 10-03-2016, 07:34 PM   #8
franken
Snap a pic of the pumpkin and the backing plate, load up the tools and go to the nearest picnpull in DFW. Go to the truck section and pull what you want.
franken is offline   Reply With Quote
Old 10-03-2016, 09:01 PM   #9
GR8-68
GR8-68's Avatar
I got two of them for you, they are threaded into it. A good torch with some heat and a heavy impact took it out.
Larry
"Project 68"
paypal.me/ldgrant
