Gray speedometer gear for a th350
Hey all - I'm not sure if I am saying this right, but I need the grey (or gray if you prefer) gear for the speedometer to work on my 84. I pulled the speedo cable off the tranny and it spins with a drill, so cable and gauge are working. Pulled the assembly off the tranny and this piece
is mangled on 4 teeth. So, the local transmission shop doesn't have them, or do the local auto parts places. Where can I get them from? Is ebay just the easiest place? |
Re: Gray speedometer gear for a th350
well....looks like I found it on rockauto. I wasn't searching in the right spot
I replaced mine on 74 C10 TH350 about a month ago. It is a Black 23 tooth. Search for tooth number and color on ebay. I also replaced gear housing (Bullet) only because of age and o-ring. It also has the ratio adapter that I disassembled and greased. Has worked great since.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice Last edited by Bandit130; 10-27-2016 at 10:49 PM. |
