Old 11-05-2016, 11:02 AM   #1
richards72chevy
richards72chevy's Avatar
Will a 15 inch hayden flex fan work?
I noticed the orielys website said not to be used with an engine 250 cid or bigger I have a 305 sbc.I cant go any bigger than 15 inches because it will hit my transmission cooler lines.
richards72chevy is offline   Reply With Quote
Old 11-06-2016, 08:58 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Will a 15 inch hayden flex fan work?
I put an 18" fan on mine and it just fits the shroud. If you're gonna be driving that thing around Oakdale CA during summer, I'm thinking it better to re-route the tranny lines and get a bigger fan. Hayden fans seems to carry that warning. Mine did too, but I ignored it. I ultamely went with a clutch fan. There are too many horror stories of flex fans pitching a blade when the rivets give out. Many of those stories can be found right here on this site.
AcampoDave is offline   Reply With Quote
Old 11-07-2016, 02:07 PM   #3
par4tom
You will have to have a shroud on that one...Central Valley Summers are brutal and if you get stuck in traffic, the shroud will be imperative!
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 11-07-2016, 04:43 PM   #4
LVPhotos
LVPhotos's Avatar
Flex-a-lite Black Magic fan 3300cfm. FITS perfectly on 1962 radiator.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-07-2016, 05:39 PM   #5
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
x2 with electric. Full throttle fan at a stop light or driving.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-07-2016, 07:11 PM   #6
Backpayne
That looks great! Does it have the probe that goes in the coolant or through fins of radiator?
Backpayne is offline   Reply With Quote
Old 11-07-2016, 08:47 PM   #7
LVPhotos
LVPhotos's Avatar
I set mine to piggyback off temperature gauge sensor next to water neck on manifold.
http://www.speedwaymotors.com/Coolin...uges,2356.html
Old 11-07-2016, 09:27 PM   #8
richards72chevy
I don't think I will use the hayden fan.If I go that route I will purchase a flexalite fan and one of their spacers.Whats the best way to wire an electric fan?I have converted my truck over to the one wire altenator.
Old 11-07-2016, 10:17 PM   #9
LVPhotos
LVPhotos's Avatar
Pic
