Old 11-15-2016, 04:29 AM   #1
Kenfuzed
Kenfuzed's Avatar
Glovebox door issue
My glovebox door doesn't align properly and is difficult to open. I've tried removing and reinstalling but I can't seem to get it to close or open correctly. There is no sign of the door being bent or warped.
When closed the door looks like it is not flush. When pushing the door button the door only opens approx 1" and sticks, then pulling it open makes a loud snap sound from the spring as if there is something catching.
It's probably something simple but I thought I'd ask rather than continue messing with it and end up scratching the new paint.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 11-16-2016, 03:32 PM   #2
phraza
phraza's Avatar
Re: Glovebox door issue
Hmm mine does the same thing, interesting to see if someone else has fixed it! I haven't really tried to fix mine yet...
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline   Reply With Quote
Old 11-16-2016, 03:37 PM   #3
Kenfuzed
Kenfuzed's Avatar
Yes it is one of those little nagging problems that has been bothering me. I'm not sure if the harsh snapping of the flat spring is normal or if I have a problem with how it is installed.
Enjoying the ride!
Old 11-16-2016, 05:47 PM   #4
ROJO12
ROJO12's Avatar
I just did mine recently and had to slightly bend up the latch. i just applied some pressure to the opening lip until it opened smoothly and closed properly. Worked for me!
ROJO12 is offline   Reply With Quote
Old 11-16-2016, 06:11 PM   #5
Kenfuzed
Kenfuzed's Avatar
Thanks I'll try to look at that. I couldn't see where anything was hitting the outer edge of the opening but perhaps it is further inside where it is snapping against the door spring.
Enjoying the ride!
Old 11-16-2016, 06:15 PM   #6
ROJO12
ROJO12's Avatar
Ken, its the upper lip that I adjusted. The spring at the bottom then took care of itself. Now when I open the glove box it pops right open.
Old 11-16-2016, 07:00 PM   #7
Kenfuzed
Kenfuzed's Avatar
Ok might be something different than what I'm experiencing. When I press the button the door pops opens approx 1 inch but sticks there, and I have to pull on the door to open further which makes a loud snapping sound as if metal is catching somewhere.
Enjoying the ride!
Old 11-17-2016, 03:08 AM   #8
nail pounder
nail pounder's Avatar
Is the bottom of the glove box door rubbing the metal part of the dash under it? You probably already have checked the screws to adjust the door up and down but double check. Just like my old Harley, mine tends to vibrate things loose over time.
nail pounder is offline   Reply With Quote
Old 11-17-2016, 03:58 AM   #9
ROJO12
ROJO12's Avatar
Ken
What you are experiencing is exactly what I was until i tweeked the upper lip Like I say it worked for me. Have a look and give it a try maybe.
Old 11-17-2016, 04:47 AM   #10
Kenfuzed
Kenfuzed's Avatar
Ken
I'll give this a shot, thanks.
Enjoying the ride!
Old 11-17-2016, 03:38 PM   #11
ACK
ACK's Avatar
Just throwing this out there. The glove box door pivots on a piece of plastic in the bottom left and right corners. It's roughly the circumference of a quarter and about a 1/4" thick. If one of them is busted or very lose, it throws everything off and the door tends to bind. If they need to be replaced, here's a link to where they can be purchased, part #12 ... http://www.lmctruck.com/features/cbe/CBECH4.htm
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 11-17-2016, 05:33 PM   #12
Kenfuzed
Kenfuzed's Avatar
Thanks for that ACK, I haven't checked since originally buying the truck a couple years ago so those could very well be worn as well.
Enjoying the ride!
Old 11-19-2016, 02:04 AM   #13
IHutch5R
Mine just started doing this same thing too after a friend opened it. Worked fine until then. Haha I'll try bending the lip also.
IHutch5R is offline   Reply With Quote
