Old 11-22-2016, 09:34 AM   #1
jhvaughn
Please help... '60 C10, LS1 - need gas tank
I'm working on building a C10 with porterbuilt setup and LS1 motor. I need to get a gas tank for the rear. It seems my options are limited for this year model, several to choose from for '63-'66. I don't think I can run the '63-'66 due to the frame size. Right now it seems my best option is the EFI Boyd tank. They are pricey, but I've heard good things about them.
Before I pull the trigger, does anyone have any other recommendations?
Heath
jhvaughn is offline   Reply With Quote
Old 11-22-2016, 09:56 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Please help... '60 C10, LS1 - need gas tank
I'm thinking they are out there: https://www.performanceonline.com/19...ank-19-Gallon/
Old 11-22-2016, 12:28 PM   #3
jhvaughn
Originally Posted by The Rocknrod View Post
Yes, that is one of the few that I've found. By the time you add the fuel pump, etc. it's up their around the same price range as the boyd tanks.
Hoping for something a little cheaper...
Thanks for your response.
Old 11-22-2016, 12:57 PM   #4
Indian113
Indian113's Avatar
On my Ls S10 I have a 16 gal fuel cell with a Speedway external fuel pump and regulator. I've put 30,000 miles on it without any problems. When I do my 64 I'm going to put a 19 gal Mustang Tank on it. Might use external Pump again.
Indian113 is offline   Reply With Quote
Old 11-22-2016, 01:39 PM   #5
LVPhotos
LVPhotos's Avatar
Tanks Inc.com has mustang regular and extra capacity tanks that fit 60-62 frames. Check faq section for those who installed.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-22-2016, 02:57 PM   #6
jhvaughn
Thanks. Looked through FAQ. Must have missed that.
