11-22-2016, 09:54 AM | #1 |
LS swap question
Gentlemen, gentlemen, lend me your ears.... I have purchased an LS, 5.3 out of a 2001 Suburban... I need to know what inline fuel pump I can use for this motor.... my understanding is I need about 60 psi, I tried the parts store, but they cant find crap without a part number or application... So if anyone knows what vehicle I can get one out of, or a part number I would appreciate it...
Thanks... |
11-22-2016, 10:17 AM | #2 |
Re: LS swap question
sub'd for info
1972 C/10 Cheyenne, Daily Driver. SOLD 1978 GMC K15 High Sierra. |
11-22-2016, 10:18 AM | #3 |
I bought the fast efi pump with a regulator it's pretty expensive but quiet and works well. You also need to add a return to the tank incase you weren't aware. A lot of guys use the corvette filter/regulator but I don't have a part number for you on that one
11-22-2016, 11:14 AM | #4 |
I think you are looking for AC Walbro GSL392 inline fuel pump. 255LPH high pressure.
Also you can use the 2002 Corvette fuel filter/regulator to make a return. But, If your fuel rail/system already has a return line I'd recommend you use it.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by 70cst; 11-24-2016 at 02:50 PM. Reason: FS offer |
11-22-2016, 11:37 AM | #5 | |
Proud owner of a 55.1 AD
Good luck with your swap, you will love it. |
11-22-2016, 12:11 PM | #6 |
Thanks for the info... the motor that I have has a regulator built into the fuel rail, so I would assume that it should work, I would just need an inline fuel pump... I have been able to find some info and see some people are using a MPE 16020 from Orileys auto, but it states that it runs 45 PSI... any thought on this?
11-22-2016, 12:27 PM | #7 |
I used Walpro on a LS6 powered street rod I built a few years ago. Worked perfect. If I remember correctly (memory isn't what it used to be) I had to have 58 PSI.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
11-22-2016, 01:41 PM | #8 |
Yep, 58 psi, and NOT vacuum/boost referenced. That factory regulator/filter setup works well. I'm using all aftermarket, because I already had a return-based fuel system, but if I had to start from scratch that's how I'd do it.
11-22-2016, 02:07 PM | #9 | |
Those kids behind the counter at Auto parts stores don't seem to know anything other than how to look up year/make/model and read what they see on the screen. The old geezers that really do know something are becoming a thing of the past as have reams of parts catalogs and diagrams that used to line the parts counter. I was a parts counter guy back in 1989 while attending college. The job required some skill and knowledge of auto parts/repair, ability to run a lathe to turn rotors and a certain amount of intelligence to not make a fool of yourself when helping out the corporate customers ( the ones who know their $hit and get extended the full discount ). -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
11-22-2016, 02:16 PM | #10 |
I could be wrong but I think the fuel pressure is regulated in the gas tank. The little device that sits on the fuel rail is some sort of buffer not a fuel pressure regulator. On the 2001 engines did they have one line running up to the fuel rail?
11-22-2016, 02:33 PM | #11 |
Yes the little pod on the side of the fuel rail is your regulator, and will not have to run a return line.
I have swapped both styles on 2 different projects for customers the Walbro pump is the best choice for the pump From speedway #960392 (gsl392) 60 psi and the install kit (I recommend will keep pump quiet) #960939 $14.99 Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
11-22-2016, 02:38 PM | #12 | ||
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
11-23-2016, 12:51 AM | #13 |
A 2001 truck engine WILL have a return line and the regulator on the fuel rail. As others have said, use a Walbro255 and run the feed line to a fuel filter then the feed line on the fuel rail and the return from the rail back to the tank.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-23-2016, 09:42 AM | #14 |
get in touch with way2lo2 (Boris)
He offers this for the LS swap crowd on his FaceBook page, I'm sure he'd offer the forum the same price. |
11-28-2016, 08:53 AM | #15 |
Thanks for all the info guys... I have fired up the motor, and it runs good...
