Old 10-11-2003, 02:00 PM   #1
RED71CHEVY
RED71CHEVY's Avatar
Lightbulb grease fittings.?!?!?!?!
how many grease fittings are there on a stock 71 c-10 front suspension. i really need to know......i thought i knew how many but......i am not sure. and can you list the locations!
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 10-11-2003, 03:25 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Here are the ones that i know of:
Upper and lower ball joints, wheel bearings (on the caps), all tie rod ends, the the bars that the A-arms pivot on. That is all i can think of now....any more that i'm forgetting?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-11-2003, 03:40 PM   #3
aesj2
Let's try again. 1 fitting at each ball joint. Total 4. 1 fitting each end of control arm pivot shaft. Total 8. 1 fitting each tie rod end. Total 4. 1 fitting drag link to pitman arm. 1 fitting drag link to idler arm. There you go. Good Luck.
aesj2 is offline   Reply With Quote
Old 10-11-2003, 07:27 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You have zerks on your bearing dust caps yellow? Do you have bearing buddys on there or something?
Old 10-11-2003, 07:46 PM   #5
lukecp
lukecp's Avatar
I pulled off the rotors to get them turned and noticed that there were grease fittings on the bearing dust caps.
What is a bearing buddy? I just repacked the wheel bearings and smeared grease all over the spindle when i put it all back togethere....
Old 10-11-2003, 07:52 PM   #6
Longhorn Man
http://www.bearingbuddy.com/
Old 10-11-2003, 07:57 PM   #7
lukecp
lukecp's Avatar
No, it dosen't have those....just a cone-shaped rounded sheetmetal cap with a grease fitting on it. Hollow on the inside.
I assumed they all had it
Old 10-11-2003, 08:03 PM   #8
Longhorn Man
Nope. Someone added those. I'm not even sure how much they would help. No way to get the rear bearings (same short coming with the bearing buddys) and mainly, when you pump into your set up, you run the risk of damaging the rear bearing seal. The bearing buddys have a spring loaded plate that will move so you won't put pressure on the seal.
Old 10-11-2003, 08:07 PM   #9
lukecp
lukecp's Avatar
Thanks.....glad i haven't put the grease gun on the fitting yet, lol.
Repacking the bearings with fresh grease is a easy job anyway.
Old 10-11-2003, 08:24 PM   #10
68C10
I've never seen zerks on those things. They are just caps to cover the nut and the bearing. I don't think the grease could even get to the bearing from the cap.
Must have been an "upgrade" by the previous owner.
68C10
1968 C10 SWB No Options but 40K original miles
1967 K20 LWB 283 4-speed
South Plainfield, NJ
68C10 is offline   Reply With Quote
Old 10-11-2003, 11:09 PM   #11
Longhorn Man
It could get to the outer bearing, but not very effectivly.
The cap m,ay blow off before the amount getting to the bearings would be effective.
Old 10-12-2003, 11:13 AM   #12
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Doesn't the Idler Arm have one where it pivots at the frame? Not the drag link, but the other end. I know my '92 chevy has one. Easily missed, and usually the first to get loose in my experience.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-12-2003, 11:21 AM   #13
Longhorn Man
Well, a quick rule of thumb I use while greasing the variouse vehicles at work that I am not too familiar with, if it moves, it probably needs lube.
So look at everything that moves, and you can't go wrong.
Old 10-12-2003, 05:18 PM   #14
Blue_71
Bloo
Blue_71's Avatar
sounds like a farmer may have owned your truck yellow we used to have 1 dust cap for the wagons that we had put a grease fitting in to grease all the wheel bearings
Blue_71 is offline   Reply With Quote
Old 10-12-2003, 07:19 PM   #15
RED71CHEVY
RED71CHEVY's Avatar
so if i counted correctly there are --18-- zerks on a stock front end, and if i add my --4-- zerks on my front swaybar that would mean i have --22-- total.
i better go and see if i gto them all..!!!
TIM
