Old 12-11-2016, 09:47 PM   #1
71chebbysb
Opinions on where to cut my frame
Got my replacement piece of frame (thanks Richard) and now I need to figure out exactly where I want to cut the old frame out to replace those giant holes where the power steering pump mounts. Any tips from those that have done it before? I think I know what I want to do but I am welcome to more opinions.
71chebbysb is offline   Reply With Quote
Old 12-11-2016, 10:26 PM   #2
ryanv70c10
Re: Opinions on where to cut my frame
I need to do the same repair and I was going to cut the entire vertical section out but leave the horizontal top and bottom sections. Replace with new piece. I also grabbed an oem doubler plate from a blazer.
ryanv70c10 is offline   Reply With Quote
Old 12-14-2016, 08:47 PM   #3
binford
I would start with removing all the paint, wire wheel it clean so you can see all the cracks.
A butt weld is not a good as a lap weld. So maybe cut where you can add a extra plate to give it strength. I would do what Ryan said so you don't loose to much original metal. Plus it will keep everything aligned up too.
binford is offline   Reply With Quote
Old 12-14-2016, 10:31 PM   #4
71chebbysb
Thanks for the replies. I was having a real hard time trying to figure out how I wanted to do the vertical cuts around the bad area so I decided to just replace the whole frame piece. I will definitely be cleaning up the entire piece and looking for cracks before I weld it to the frame. I will also put a fishmouth piece on the inside to reinforce the joint.
Old 12-15-2016, 10:14 AM   #5
boostedc10
boostedc10's Avatar
71chebby who did you get the frame piece from? I'm looking for a piece on the passenger side where the front shock locator hole is.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 12-16-2016, 08:54 AM   #6
71chebbysb
I got the frame piece from richard2717 on this forum. Very reasonable price and he had it shipped to me the next day.
