Old 12-23-2016, 01:20 PM   #1
evan
evan's Avatar
Rockers and cab corners from a donor truck?
I've got a donor truck with good rockers and cab corners. Is it worth the effort (or even possible) to cut it up to use those or should I just buy aftermarket pieces?
Evan B.
evan is offline   Reply With Quote
Old 12-23-2016, 02:39 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Rockers and cab corners from a donor truck?
It wouldn't be to me...they way my luck goes I would destroy those parts trying to save them..I would just buy the aftermarket even though the quality may not be as good as oem..all you can do is try to cut them loose and see what happens..is the donor cab worth saving or is it just a parts donor.if it doesn't work out you can always buy aftermarket...all you have invested is time..
Old 12-23-2016, 02:45 PM   #3
74CustomK20
74CustomK20's Avatar
Would it be easier to repair what's wrong on the good cab n rocker corner can and use it? If not I wouldn't bother either.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-23-2016, 03:35 PM   #4
evan
evan's Avatar
The donor cab was in a head on collision with damage up around the windshield so I don't think it's worth saving. I might try cutting some pieces out and see where that gets me.
Evan B.
Old 12-23-2016, 03:52 PM   #5
cochino12
It followed me home?
cochino12's Avatar
I've done it before to get some small rocker pieces and cab corners. Worked great.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-23-2016, 08:25 PM   #6
65standard
65standard's Avatar
New parts are super cheap. I wouldn't waste my time cutting up a donor cab for the pieces.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 12-24-2016, 04:10 AM   #7
andrewmp6
New parts are thinner and the fit can be crappy tho,If you got the time and use a spot weld cutter id take them out if it was me.
andrewmp6 is offline   Reply With Quote
Old 12-24-2016, 07:14 AM   #8
Desert1957
Desert1957's Avatar
Is this true? If so where can you get original thickness replacement parts?
Desert
Desert1957 is offline   Reply With Quote
Old 12-24-2016, 09:12 AM   #9
Low69CST
Why not switch cabs? Was the cab damaged? If the rockers/corners are more solid, I would guess the rest is too.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 12-24-2016, 09:24 AM   #10
andrewmp6
Used oem parts or from gm/nos on ebay is about it.
Old 12-24-2016, 10:28 AM   #11
barry1982
I just completed welding in inner/outer cab corners, and inner/outer rockers on my 82. You have to shop around. Some after-market pieces are thin / crappy while others are as thick or thicker than OEM. Find a distributor for "Key Parts". Not sure about their fenders/doors, but the rockers / cab corners were great.
barry1982 is offline   Reply With Quote
Old 12-24-2016, 03:33 PM   #12
65standard
65standard's Avatar
I used classic parts and the parts are 19ga. just like original. Fit was perfect.
