![]() Join Date: Jun 2007
Super nice 64-66 AC BBW cab
Here is something a bunch of you wanted Santa to bring but he didn't come through for you, so here's your shot. 1800 or best offer on this beauty.
here's whats so great about it: Factory paint everywhere so no prior work or bondo Southeastern US cab so no salt has ever touched it perfect firewall and L/R vent boxes AC uncut radio hole dash beautiful rust free cab corners beautiful rust free inner and outer roof including drip rail Beautiful rust free BBW panel and gas tank area inside and out Beautiful rust free floorpans rusted areas are the topside of the drivers outer rocker, and at least one small hole or two in each inner rocker, and the vertical sheetmetal called the Kick panel (where the pull vents are) is rusted off an inch or two up from where that panel meets the floorpan - same spot they are all rusted in. So, the cab is not perfect but as close as you will find and needs the least amount of work to be repaired. Could be fixed by simple metal patching rather than full replacement on the inner rockers and probably doesn't need a pass outer, but needs a drivers outer for sure - the rest can all be fixed with your welder and a little time grinding..... LOCATION / SHIPPING: figure shipping at .75 cents per mile from Joppa AL 35087 and call Randy Kroth at 256 200 2824 to get a firm quote for carrying it to you. Otherwise it has to be strapped to an oversized pallet which is 8 x 4 wide and weighs probably 800 to 1000 lbs total if I had to guess - we can forklift load onto your freight carrier. Use www.uship.com to get reight carrier quotes to haul it vs Randy carrying it. OTHER PARTS: Grey cab in pics sold yesterday and the yellow one is not for sale - I do have a myriad of other parts for 60's trucks, so feel free to inquire - TEXT or call Steve at 256 486 1988
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
| Bookmarks |
