![]() Join Date: May 2014
Short bed conversion
So I was looking to cut my truck down I know 20 inches needs to be removed does anybody have a good diagram of where to cut and what else needs to be changed besides fuel an brake lines and the driveshaft
Oh and on an other note if anybody knows where to get a shortbed stepside bed that will fit a 74 c10 please hit me up |
Re: Short bed conversion
14" between the front two bed mounting holes. How you cut is a common argument, but I went with a 45 degree cut myself. There really isn't a precise measurement from the front hole or back hole, just remove the 14" between them. The e-brake cable will need changed or modified and the gas tank will need to be changed. Either a short bed tank needs swapped in or as many do, a blazer tank can be installed.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#3 | |
So how much do you cut off the back |
That seems to vary a bit. I cut about 3", but I haven't cut down my bed yet so it might not be right.
It followed me home?
I've done three of these conversions and I've always cut about 3" off the back, I left as much frame there as possible to have room for bumper brackets.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#6 | |
Also where did you get the shortbeds from you put on the swaps |
The bed bolts to the frame so...no, no new mounting points. I cut my bed down to a short bed. That is not the best route though. Find a used bed or buy all the parts from LMC to build a new one.
There is also a rear crossmember that can be moved forward. The holes were already drilled in the 1/2 ton I did but you'll need to drill them if you are working on a crew cab.
Shortening brake lines & re-routing or shortening electrical.
SWB specific gas tanks or aftermarket swap.
great info, I'm in for this mod to my LB as well! Post up pics if you can when you start the project brother!
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
You could give a look through my shortened bed write up:
http://www.gwellwood.com/project-car...ing-the-frame/
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
| Bookmarks |
