Courtesy lights install question.
I'm about to install my under dash courtesy lights.
My question is this What is the best way to drill the holes to route the wiring for the door jamb switches? From what I can tell I have to go through the door jamb, the inner cab panel and then the kick panel, up under the dash. Is there a way to get around the panel that's in between? I might take a trip out to my favorite salvage yard to look at one of the bare cabs. |
#2 | |
![]() ![]() Join Date: Feb 2009
Re: Courtesy lights install question.
There's a hole in the center of that square. It's threaded for the original door jamb switch (likely stripped if original Ha!). There's a hole in the kick panel, which is 1" below and 1/2" to the rear of the dash panel's rear bottom corner.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
My truck is a 70, and didn't come with the lights.
Are you saying the raised part of the door jamb is threaded behind the sheet metal? I understand the rest of what you said, thanks |
Post Whore
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5 | |
Does this mean that all truck have wiring, just not the holes and the switches? Is it that simple to install?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Jul 2016
The wiring harness is not in all trucks and the hole is not threaded. The door pin switch just threads into the sheet metal after you drill the hole. Do a practice hole in some scrap to get the hole size close so the switch will thread into the sheet metal.
#7 | |
Nice suggestion too. Mine are stripped. I guess the real fix is to weld and re-drill.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I know this is not exactly what you asked about your under dash light install but you will get to this part after your switches are installed. The attached thread show the under dash harness board member Roger Koop made up. I bought one form him and have installed it on my truck with LED Bulbs. The attached pics show how I installed it using existing hole along the bottom of the dash which all our trucks have.
http://67-72chevytrucks.com/vboard/s...d.php?t=618187
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#9 | |
Thanks Keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 01-19-2017 at 10:13 PM. |
#10 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=714329
You can get the rubber grommets at any parts store. Not sure on the bulb, they came with the harness. I got my harness out of a mid 80s truck, a long time ago, but it would be real easy to create. When you go out to your favorite yard, look in any "square bodies", and look for the door switches. Then just remove the whole harness. The switches disconnect from the wire, so they're quite easy to get out
You can try tweaking the hole a bit then reinstall and leave it alone...
#13 | |
Incidentally, some drill and use a tap. Apparently that's not necessary, though may be cleaner.............can't really say.
